VHS player 2001 Dodge Grand Caravan
Factory VHS sound is distorted, just white noise.
SOURCE: ticking sound on 2001 dodge grand caravan 135000mi
Turns out it was the water pump. The plastic impeller on the inside had broken in half- split almost right down the middle. there was just enough of the impeller remaining to attach to the shaft and pump water. Apparently, it was pumping enough to keep the temp under control. So, I never noticed it overheating. The piece that had broken off had gotten lodged in a recessed area inside the pump housing. The ticking noise was being generated as the intact half of the impeller rotated and hit the broken off half.
I narrowed down the problem by removing the belt and cranking the engine temporarily. With the belt off and the pump not turning, the sound was gone. I could spin the pump pulley by hand and faintly hear the noise.
A new pump cost me $35 and took about two and a half hours to replace.
Posted on Jan 28, 2009
SOURCE: How can I replace the stereo of a 2002 dodge caravan with 2001
The whole front plastic cover over the stereo and heater controls is screwed in with two screws at the bottom of the cover, just above the cupholders. Take out those two screws and then pop off the cover, which is held in place by clips up the sides and at the top. There are four bolt/screws that hold the radio/cassette/cd (whichever you have) in place. Unscrew them and replace the stereo. Plugs SHOULD fit, and if they do just replug it and you're good to go. If the plugs DON'T match up, get a wiring harness from Best Buy or Walmart.
But be warned! Just because the stereos look VERY similar and fit very nicely into the other spot in the dash, they may NOT have matching wiring plugs. I just put a 2003 Neon CD player into my 2002 Caravan, and the harnesses didn't match up and neither did the antenna.
Posted on Feb 18, 2009
SOURCE: 2003 Dodge Grand Caravan Front Noise
I had the same problem, my mechanic has had this same problem with other 2003 grand caravans. Flush the power steering fluid, replace it with ATF+4 and add Lucas power steering additive. Apparently dodge has posted the fluid that was originally used is causing this problem. $100 and it is purring like a kitten
Posted on Feb 25, 2009
  • 40 Answers
SOURCE: Replacing the starter on 2001 Dodge Grand Caravan
with most front wheel drives you must remove the passenger tire and reach through to the starter bolt with an extension and if I remember write with a 15 mm socket you can reach through and take out the bolt
Posted on Jun 20, 2009
SOURCE: NEEED FUSE FUSE BOX LAYOUT FOR 2003 DODGE GRAND CARAVAN
You can get free owners manuals online at:
http://www.edmunds.com/ownership/howto/articles/120189/article.html
or just type "owners manuals" in your search.
Here is a post I found that worked for my 2005 caravan.
For a 2001 Dodge Caravan: The owner's manual is vague, only stating that all fuses are under the hood in the fuse box, no diagrams. Once you have removed the fusebox cover, the diagrams for what each fuse does is provided under the lid. UNCLEARLY marked is the radio fuse, a 20amp fuse located 2nd row from top to the right of the accessory relay. It is marked: RDO/IP IGN.
Jake
Posted on Sep 19, 2009
2001 dodge grand caravan wants to start it goes through the starting procedures then chokes out
could be a timing issue and the loud noise is a backfire through the exhaust manifold
Feb 16, 2015 | 2001 Dodge Grand Caravan
Noise from my 2001 dodge grand caravan. Sounds like a suspension noise
90% of front suspension noise on caravans is sway bar bushings and sway bar links.Next is upper strut bearings.
Jun 30, 2017 | 2001 Dodge Caravan
2001 Dodge Grand Caravan. has been making a loud whining noise for about a week. started slipping last night. seems to get worse when going from a complete stop and when shifting into gears. other than...
MOST LIKELY HAS A PLUGGED TRANSMISSION FILTER.
TORQUE CONVERTOR CLUTCH FAILURE COMMON.
CHANGE TRANSMISSION FILTER AND ROAD TEST.
IF NOISE IS GONE AND RUNS NORMALLY, CHANGE TORQUE CONVERTOR AND RESEAL TRANSMISSION.
May 19, 2010 | 2001 Dodge Grand Caravan
Why does my dodge grand garavan make loud noise
could be a problem with your flywheel or if the starter was just replaced and you started hearing the noise then it could have to be shimmed out from the flywheel. Could be a starter issue.
Jan 28, 2010 | 2001 Dodge Grand Caravan
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
Televison & Video Logo
Top Televison & Video Experts
