Question about JVC TH-BA1 Soundbar System with Wireless Subwoofer
JVC TH BA1 problem w subwoofer
Hello. The subwoofer barely puts out any sound. It used to be loud. Also, has issues with light going blue and red on the subwoofer.
Nightdiver
  • 116 Answers
SOURCE: Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
Posted on May 19, 2006
bluenadas
  • 203 Answers
SOURCE: SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Posted on Jun 15, 2007
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
tech48
  • 624 Answers
SOURCE: JVC TH-M505 No Sound
It is possible that a fuse has blown in the sub-woofer box. This unit has the entire amplifier built right into the sub-woofer. It also has a number of fuses in it. I have found that over the years fixing these units that if a fuse is blown you will also have more serious problems in the amp circuit. That is usually why the fuse will blow. They sometimes even have a problem in the main head unit with a digital transistor that is a surface mounted transistor that will cause this problem also. This transistor is part of the turn on circuit that signals the sub-woofer to turn on when the head unit is turned on. None of these problems are an easy fix I am sorry to say.
If you have at least a little experience with electronics and the right tools, like a multimeter and soldering equipment, I may be able to help you figure out the problem. But be aware that these are not easy to fix, and you may spend lots of time trying to figure it out just to find out that you will still need to take it in to a service center and in many cases when somebody tries to fix these type of units and have no experience with them they often cause more problems than they have started with.
For starters you can at least check the fuses, but please be sure to unplug the entire unit from the wall outlet before doing anything, there is a big risk of electrical shock.
The bottom of the sub-woofer has 6 screws in it (If I remember right) and those 6 screws must come out, they are rather big and you must use a number 2 phillips head screwdriver. Then after that you must take out all the screws from around the edges of the black metal panel where the speakers plug in to. When those are all out you can pull the amplifier unit right out of the sub-woofer box. Be careful when you pull it out, you will need to unplug a set of wires to get it all the way out, maybe two sets of wires, I am going off of just my memory right now, but if you need more help I will look up the service manual to help you more.
You will find at least one fuse right near the board where the A/C plug goes to and then you will find a few more fuses on the board that is on the right side while looking at the amp block from the same position you pull it out from and this board is plugged into the bottom board and is vertical but the short side is up and down, the long side is going towards the back of the amp and it is running along the metal chassis on that right side.
I hope this helps you, if you need more help just post your questions here.
Dave
Posted on Nov 26, 2008
SOURCE: jvc th-c6 subwoofer won't turn on
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
Posted on Mar 16, 2009
Why? Jvc sound bar turning in by itself, no one turned it on, three mornings in a row , turned on radio automatically???
It sounds that you have accidently set up an alarm setting that is set to wake you up in the morning!
Look in the manual and see what it says about timer settings.
Aug 21, 2016 | JVC TH-BA1 Soundbar System with Wireless...
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
How do I turn off timer on a J V C soundbar
I am not aware of timer function. Visit http://books.jvc.com/booklist.asp?Model=th-ba1 to download the manual. Send me a picture of what you see on display. or explain in detail
Feb 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
My subwoofer shuts off when I turn it up too loud. How do I fix it?
Don't turn it up so loud.
Or get a bigger subwoofer.
It's got a junk 6.5 inch speaker and the amp barely does 50 clean watts.
Claims 167 Watts at 10% distortion - impossible when it is drawing 160.
TOTAL BS.
Drive it too hard and protection circuit will cut in and shut it down.
Dec 31, 2010 | JVC TH-C40 System
Jan 12, 2008 | JVC TH-M505 System
Th-R1 no pwoer to subwoofer - transformer u/s?
my power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Oct 14, 2007 | Audio Players & Recorders
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
System shuts down whenever there is a loud noise on a DVD
I had the same problem. Found out the wires were in contact with one another on one of the speakers.
Nov 26, 2006 | JVC TH-M505 System
Oct 21, 2006 | JVC TH-M505 System
JVC TH-BA1 Soundbar System with Wireless Subwoofer Logo
63 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
