Question about GE DWSR483GBWW / DWSR483GBCC Gas Dryer
Gas dryer keeps triping the breaker dwsr483gg7cc
Every tuime that we turn on the dryer it surges and the breaker trips
  • 3 Answers
Please provide more detail about the 'surge'?
Posted on Mar 13, 2009
Tcl 770 keeps triping power
Check to make sure the breaker is rated for the current draw of the dryer. If it is, you MAY have a bad breaker. Replace your breaker and If the dryer is still tripping the breaker, your dryer needs to be repaired by a qualified technician.... the heating element is probably burned up and shorting out.
Mar 02, 2014 | Hotpoint Dryers
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
Walkin frezzer keeps triping breaker
First thing I would do is remove the wires to the relay on the compressor and check it for shorts between the pins to the frame. Probably a shorted compressor or it could be the relay itself but I doubt it.
Jul 09, 2012 | Dryers
The dryer keeps triping the breaker when pluged in and not runing
You need to check your power cord. Here is a video to walk you thru it.
Nov 26, 2010 | Kenmore 72062 Gas Dryer
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
AC main Breaker
There are many things that would cause this problem. It would be best to have a qualified technician test your system to find the cause.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
Clothes Dryer not working
if it is tripping the breaker right away there is an issue with the drier shorting to ground. unplug and look for a broken wire in the drier. if the drier runs for 10-15 min maybe 30 before it trips the breaker. there is a loose connection in the wiring. either at the junction box in the wall behind the dryer or at the breaker panel. If it is in the electrical I would call an electritian. Good Luck!
Sep 24, 2007 | GE DBSR453EBWW Electric Dryer
GE DWSR483GBWW / DWSR483GBCC Gas Dryer Logo
85 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
