Question about Dryers
Coleman powermate pulse 1000 generator
Wires are off on control panel need to see a wiring diagram so i can hook them back up
aborcass
  • 2651 Answers
SOURCE: wiring harness diagram
which wires popped of exactly ??? the wires from light/door switch?? grey, white, black, wires???if so thats the order top to bottom
Posted on Mar 18, 2008
SOURCE: generator fuel-oil mixture
My manual for my Powermate 1000 says 18:1 fuel mixture.
Posted on Sep 13, 2008
drolllord
  • 9 Answers
SOURCE: Need manual for coleman powermate 1850 generator
google it! use the specific search terms, Coleman power pulse 1850 - it worked for me!
Posted on Jun 19, 2009
protek480
  • 1723 Answers
SOURCE: I have a Coleman Powermate Pulse 1750 generator.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Posted on Jun 26, 2009
protek480
  • 1723 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
I need a wiring diagram for my powermate 5700? Do to my dog chewing off the wires
you need 2 replace the dog...! (BEFORE THE WIRING job) ...that's a really tight spot they're in....
HE'LL SEE NEW WIRES AND SAY....
OH GOODY....I bet he'll like this ! that's what he gets for leaving me home alone ....i'll show HIM !
Mar 08, 2014 | Coleman Powermate Powermate 5000W...
How do I hook up to dryer plug
Do NOT hookup to a dryer plug, it is dangerous to back feed a panel through a dryer plug. Besides dryer plugs (older ones) have a N and G combined in a 3 prong plug, new dryers and wiring have 4 prong where the N and G are correctly seperated. Do not backfeed !
Feb 04, 2013 | Coleman Powermate Powermate 5000W...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
I have a coleman powermate pulse 1800ex generator w/subaru engine. It runs and produces no electricity.
try flipping the breaker or fuse this could be it or one of the wires came off the plug in or the plug went bad or the diod blew but all of these cane be fixed pretty easyjust need a meter to see what is bad good luck
Aug 03, 2011 | Coleman Powermate Powermate 5000W...
Wolf generator fitting a new switch 110 v to 240 v
frank...send me a photo of this part and other photos wll be helpfull....i'll be glad to help u /...
sal_kh_sab@yahoo.com
Mar 03, 2009 | Coleman Powermate Powermate 5000W...
Hello I have a coleman powermate 5000 that i need a wiring diagram for the brigg and stratton moter some of the wiring has be destroyed and i need a diagram to get it back running can you help me PLEASE....
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
Dryers Logo
57 people viewed this question
Top Dryers Experts
