Question about Canon Office Equipment & Supplies
Im trying to email a picture to clubpenguin that i drew
The cannon printer tells me to press color or black and white, so i press black and white, nothing happens. it wont load to my hp computer.
  • 10,865 Answers
Your quick fix here would be to take your picture and the email address to a staples or similar store and use their equipment to email the scan that u do there.
As far as using your own printer, the first question is does yout printer also have a scan function? If no then you can't do what u hope to do on it. If yes, then you need the printer disk. Put it in your printer and load the software for the printer, then you should be up and running.
please mark my answer as a fixya!
Posted on Mar 13, 2009
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
My cannon mp258 cannot print, message show that ink to slow,and the ink indicator appear the Colored ink is almost empty .and also i try to photo copy black and white document but i cannot photo copy even...
Yes. You cannot use the printer even in black and white, until the color cartridge is replaced. They are designed to check the levels of the both black and color cartridges.
Oct 18, 2017 | Computers & Internet
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
My canon printer wont scan my picture to my hp computer
You will need to have installed the software that comes with your printer for scanning and the other functions before these buttons will work.
There may also be settings in the software which dictate what the buttons will do that need to be defined.
I'd check your CD and see if there's anything you didn't bother to install originally and then see if that fixes the problem.
Mar 12, 2009 | Canon Office Equipment & Supplies
My cannon ip 4000r printer has ran out of black the small cartrage but my big cartridge is full but will not print black pls can you help
the small one is for black the bigger one is for color which is Magent , cyan, and yellow, you need to buy a new cartridge for black im afraid
Nov 27, 2008 | Cannon Office Equipment & Supplies
Getting to print BLACK & WHITE direct from the comp screen which has colour
when you get the window of the printer go to preferences , then on top of window click color , then where it says COLOR OPTIONS , unclick the PRINT IN GRAYSCALE (uncheck the box) then click OK . and try again . hope this helps
May 01, 2008 | HP LaserJet 5200tn Printer
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
35 people viewed this question
old marine
old marine
