I am having some problems with my hard drive. It was working fine and then I was having some problems with my computer while it was plugged it. The computer froze, so I manually turned it off. I hadn't safely ejected the hard drive. When I turned my computer back on and plugged in the hard drive, the hard drive (g drive) no longer appeared with the name I have given it, but rather with g drive. When I click to open, it asks if I want to format the drive. Under properties, it says that the drive has 0 bytes of used space and 0 bytes of free space. I don't understand what is happening?! Is everything lost? Is there any way of recovering the data that is in there? I would really appreciate any help!!!
Thanks!
Comments:
Aug 05, 2007
- P.S. The light in front of the drive is red far more than usual. It is usually blue most of the time.
-   me issue... external hdd and powersurge on usb hub
rebooted and now lost external hdd. xp says its unformated.
on going to my computer no size is indicated on the drive (drive letter is there)
On going to do XP checks on the drive it says the drive is RAW
-   I have the LaCie 250GB I was having trouble with my computer and the external drive disconnected and stated that it had been removed unsafely. I have plugged it back into my MacBook (OS X version) and it no longer connects to my computer. It used to just pop up and now it doesn't. The Blue light is on and it appears to be working. I have tried both the USB and the FireWire cords. Help!!-   hi_need_help
Jun 19, 2008
-   I am having some problems with my the hard drive (g drive) no longer appeared with the name I have given it, but rather with g drive. When I click to open, it asks if I want to format the drive. Under properties, it says that the drive has 0 bytes of used space -   ferrobboss
Jun 19, 2008
-   I am having some problems with my hard drive, the hard drive (f drive) no longer appeared with the name I have given it, but rather with g drive. When I click to open, it asks if I want to format the drive. Under properties, it says that the drive has 0 bytes of used space and 0 bytes of free space. -   ferrobboss
Jun 08, 2008
-   I dropped my toshiba harddrive and all of a sudden my computer cant read it, what can I do to recover my data in the hard drive?-   mrmutaps
1. "Is the data recoverable?" Yes but the manner by which it can be recovered can be either very expensive (their are firms whose specialty id data recovery) or none at all if you do DIY (do it yourself) or worst case not economical reasonable but recovery possible. I would assume that your would want to try DIY. 1.1 Run diagnostic on the external drive using scandisk, Norton Disk Doctor, Partition Magic's ChkDsk and/or Check Errors. Recovery can be done using a recovery software such as GetDataBack; or 1.2 You need an external desktop PC, a working knowledge of computer hardware. You have to disassemble the external HD and remove the actual HD. Physicall connect it to the 2nd PC (desktop) as a seconday Master either by IDE or SATA as applicable. If detected by the desktop PC in the bios, you should be able to work on it even if with errors; 1.3 If mechanical problem or otherwise, you may want to check out this posting > http://www.fixya.com/support/t162904-sea... Hope this works out for you and/or give you some ideas. Pls post again how things turn up. Good luck and kind regards.
well i turned my playstation 3 on this morning and it said coudnt said the harddisk drive coudnt be...
(More)
well i turned my playstation 3 on this morning and it said coudnt said the harddisk drive coudnt be found i removed the harddisk cleaned it put it back in still the same error message is comming up
I need a USB cable for my Beyond Micro. My Beyond Micro has a USB port. I don't see a model number...
(More)
I need a USB cable for my Beyond Micro. My Beyond Micro has a USB port. I don't see a model number on the unit. It appears that I need a USB cable with the same type of connection that goes into my USB computer port, a USB plug on each end.
I have the Samsung Toco phone which is now diplaying the message demsbl boot loader for msm6288...
(More)
I have the Samsung Toco phone which is now diplaying the message demsbl boot loader for msm6288 downloader ver 5.32, I don't seem to be able to turn the phone on, would appreciate any help.
my hdd has stopped connecting properly with my laptop, it shows up in my computer but you are unable...
(More)
my hdd has stopped connecting properly with my laptop, it shows up in my computer but you are unable to access it, chkdsk does not run either. Are there any other solutions for scanning it and working out exactly whats wrong with the drive?
