Question about Philips Magnavox MPD845
My portable player won't sync music..reads "iddataaai"
I have a Magnavox portbable device that won't sync music...or turn on..'cept for the "iddataaai" that appears on the screen...idk..I think my computer cleared the device and won't read or get access to it..but idk what to do about it..I'm lost and I need to fix it..plz and thank you...
  • 3 Answers
My Philips MP3 player had the same problem after I saved some non-music files onto it through USB connection. After I deleted these files, it seems to be working okay again. If it doesn't work, I guess you can also try re-formating it.
Posted on Oct 15, 2009
HOW TO GET MY Mp3 PLAYER NWZ-W252 IN MY COMPUTER(WINDOWS7 ULTIMATE)
  1. Install the Windows Media Player software version 11 included with the Walkman® MP3 player.
  2. Connect your portable player to the computer and start the Windows Media player software.
  3. In the Windows Media Player window, click the Sync button. NOTE: If this is the first time using your portable player with Windows Media Player, you will be prompted to name your device. Type a name for your device and then click Finish .
  4. Your portable player will be represented in the right pane. Drag music files to the right pane.
  5. After you have added all of the music files, click the Start Sync button. The song files in the Sync list will be transferred to your portable player.
Mar 18, 2011 | Sony NWZ-W252 MP3 Player
Trying to syn music to my mp3 insignia
It may not be anything you are doing wrong. You will have to see how your player is seen buy your computer. Go to your control panel -> System -> device manager --> Look for your player there, does it show up as a Portable Device? NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode.)
It should sync with Media player if it shows up as a Portable device - but if it shows up as a Mass storage device all you have to do is drag and drop what you want into the right folder on the player.
Apr 29, 2010 | Insignia Kix MP3 Player
How do i transfer music from my pc to my android
Install the software that came with your Android or if Windows XP and above can see your Android use Windows Media Player (see notes below for Windows 7)
Sync music, pictures, contacts, and calendars with a mobile device
There are two ways to sync a mobile phone, portable music player, or other mobile device with your computer. You can install the sync software that many manufacturers include with their devices, or you can use the new Device Stage feature in this version of Windows if your device supports this feature.
Device Stage lets you sync music, contacts, calendars, and other files and information with a compatible mobile device. It also allows you to perform other device-related tasks that vary depending on the device, such as creating ringtones for a mobile phone. What files and information you can sync depends on the type of device you have and what it supports. For example, you may be able to sync contacts and calendars with a smartphone, but not with a portable music player.
To see which types of files and information you can sync with your device, connect the device to your computer. If your device is compatible with Device Stage, this feature will open automatically. (If you've already set up your device to sync, Device Stage will open, but it will appear minimized on your Windows taskbar.) Device Stage will list various tasks you can perform with your device, including sync setup.
The Device Stage sync setup page
Notes
  • Device Stage is customized for each device by the manufacturer of that device, and displays different options for different devices. If you have more than one device connected to your computer, you can have more than one instance of Device Stage open at the same time.
  • To find out if a device will work with Device Stage, you can also check with the manufacturer or look at the device specifications. For a mobile phone, music player, digital camera, or other mobile device to work with Device Stage, the manufacturer must add compatible software (also called firmware) to the device.
Jan 19, 2010 | Google Android
How do i sync music from my computer to my hitachi 8gb dmp860
Connect ur device to your computer through a usb cable. If your device shall be detected as a portable Hard disk drive. You can see that by checking My computer.OR you can start the windows media player, once you have connected your device to laptop/ computer. It shall automatically give you an option to sync music
Dec 29, 2009 | Hitachi DMP-7 MP3 Player
My mp3 wont play the music just says iddataaai and it turns off
Apr 08, 2009 | Philips Audio Players & Recorders
WHAT DOES iddataaai CODE MEAN
Jan 24, 2009 | RCA (DVDCP33) Media
Sansa e260
You need to synch them to Rhapsody or whatever music service you pulled the songs from. also, make sure your music service subscription supports transfer to portable devices instead of simple transfer to a computer.
Jan 15, 2009 | SanDisk Sansa e260 MP3 Player
Download music to my scandisk sansa e260
When you turn on the player, select the music menu, and then scroll down until the playlists logo appears - select that and then your playlist name should be there.
If it still isn't there, then the songs that you tried to sync have some sort of licensing restriction on them that does not allow them to be synced to a portable device - wmp will show them as synced, but alas - they will never actually show up on the player.
May 22, 2008 | SanDisk Sansa e260 MP3 Player
Sansa keeps shutting off/ wont read memory disk
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e260 MP3 Player
Unable to sync music
What happened when you tried to sync? it could be a device certificate error...what i would recommend you to do is to sync using your windows media player...assuming that you have windows media player 11...open up your windows media player and click on sync..then you can drag the tracks you want to sync and then click on start sync...if you are not able to transfer the songs to it..use a song that is not from yahoo like the sample one that came with your computer and see what happen...if that doesnt solve the problem check your usb mode..it should be under MTP mode or auto....then open up your windows media player and format the device there...after you have done that..that should solve the problem you are having..let me know what the outcome is....
Jan 06, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Philips Magnavox MPD845 Logo
235 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
