Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Lawn mower starts then dies
Okay, so, I was using the mower and it just died out of nowhere (I didn't hit anything). I went to start it back up and then the rope was yanked out of my hand. I did some research and found that it was probably the flywheel key. I looked at the key and everything was fine. I replaced it anyway. I pulled the head off to see when it was firing... everything seemed to be normal. put everything back together and it is still snapping the pull string from my hand. I went ahead and cleaned the carb as well as the tank and checked the fuel lines. I am not sure on where to go from here.. Is the mower toast?
  • 97 Answers
Sounds like ur timing gears have jumped a cog or two. That's the gears at the crankshaft to the camshaft. Pretty big job if you don't know what you are doing.
Posted on Dec 28, 2013
SOURCE: lawn mower dieing pulled spark plug (oil on plug)
Oil on the plug might mean you have excessive cylinder wear and it is causing oil to get into the engine and foul the plug.
You can try to a new plug and see if it runs longer before fouling but realistically you are probably looking at getting a new mower very soon.
Posted on Aug 08, 2010
barterjoe
  • 338 Answers
SOURCE: lawn mower starts but makes
I hope this helps you. :
http://www.fixya.com/support/r8367428-starts_dies_common_engine_problem
I would recommend using carburetor cleaner and flush out the jets.
Joe
Posted on Apr 05, 2011
  • 111 Answers
SOURCE: when trying to start lawn mower,engine turns over
The flywheel key could be sheared. This is a problem that occurs if you have hit anything with the blade. It usually takes quite a hit to knock out the flywheel key. Here is a video to help you replace the flywheel key.
Posted on Apr 03, 2011
2strokeJim
  • 577 Answers
SOURCE: fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
Posted on May 15, 2012
timber777312
  • 11 Answers
SOURCE: Briggs & Stratton Starts but dies after few seconds Power Lawn Mowers
Add some fuel stabilizer to your gas, try starting again, if this doesn't work check your fuel line coming from the tank make sure it is not pluged if you have a fuel filter replace it with a new one.
Posted on Jul 25, 2012
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Jul 25, 2012 | Briggs & Stratton Garden
I have a Poulan push mower that after mowing in a ditch started making a loud noise and running rough. It almost sounded as if metal was hitting metal. The mower was vibrating more than normal. I checked...
If you are sure the oil level is correct then it sounds like it's about to die, unfortunately. A pine cone shouldn't cause any damage, but a large branch may do so. Was it smoking before you shut it down? The vibration could be caused from a bent blade. It could also be caused from a part breaking in the motor. I wish I could have given you better news!
Good Luck,
Jim
Aug 13, 2011 | Poulan "Poulan" Push Mower
My lawn tractor died and now is readind dead but the battery is new
Sounds like your charging system is burnt out or your battery cables wheren't tight enough when you reinstalled your new battery and as soon as you started it the first time and you ran the battery down it didn't charge, take the cables back off and clean them greese them up and put them back on and tight them up and charge the battery up and you should be good to go
Jul 27, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
Riding mower 14hp briggs & stratton will not stay running, new solenoid, new spark plug, new air filter, new fuel line and filter. At first it didn't want to start solenoid fixed that. It started ran...
Check the belt/s and make sure they are clear. If they are okay, check the governor spring. If the spring is gone, it will start but as soon as a load is put on it will stall. Good luck...Lee
May 29, 2010 | Garden
Poulan pro lawn mower starts & dies
unless this mower is older then i am, it has no points or condenser. It has only a magnito. Sounds more like a plugged up carberator.
Apr 30, 2010 | Garden
Lawn mower won't start
sound like timing is off sherd a key in flywheel
take cover off where you pull the rope and then
take off nut off flywheel its going to be tight and hard to get off but can be done take a screwdriver to hold flywheel ones the nut off look around shaft see if flywheel key is sherd
or pry off flywheel be carefull dont damage anything if sherd replace key
Jul 21, 2009 | Garden
I have a honda mower and hit a big rock.
the oil ring is shot, add some oil sealer to oil ,worked for me
Jul 14, 2009 | Garden
Murray lawnmower
you may just need to remove the nut that holds the float bowl, and inspect the nut itself, half way up the nut should be a little tiny hole in the side.
use a bread tie stripped of the plastic covering and unclog this little hole, then replace the nut , when that hole becomes plugged the main jet cannot get fuel for the venturi pipe, thus the mower will start and hit a couple times then die immediately, that may fix the problem
Sep 15, 2008 | Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
279 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
