Question about Datel Action Replay for Nintendo DS
Action replay code manager just stopped working?
I connected my action replay and everything was fine but then as my ds was listing its contents the code manager just went back to those coloured dots that keep rotating and then my windows told me that the code manager had just stopped working and to close the program while they looked for a solution. i tried re-installing code manager but it just did the same thing what do i do?
  • 5 more comments
  • Anonymous Mar 28, 2009
    my code manager isnt turning on
  • Anonymous Apr 04, 2009
    My action replay was working just fine then it stoped working and then it didnt work at all . I need assitance on how to ake it work again
  • Anonymous Apr 18, 2009
    mine isn't working either. it says a problem caused the program to stop working correctly. windows will close the program and notify you if a solution available. please give me the answer in simple terms i have no clue what a Virtual Splint is.
  • sam199511 May 08, 2009
    how do i do that?
  • Anonymous May 12, 2009
    same problem exept it wont even open! when i try theres a popup that says "error" and some other stuff. i dont put the disk in.
  • can_manu May 15, 2009
    i opend my action replay code manager and connected my NDS with the action replay cartidge inside but in my mode manager my DS but it was like it wasn't connected at all...when i tried to update my codes a window popped up saying "yopu have to connect your action replay before updating" i thought it was the USB that was isfunctioning but my PC had detected the NDS so the problem i with the code manager
  • Anonymous May 19, 2009
    my action replay code manager is not working I tried my best to fix it but it said not responding it said not responding and i had to close. I re installed it it did the same thing
  • 12 Answers
Your problem is tricky, but solvable. The problem you are dealing with here is your AR ID is not matching up with the AR disc, using a Virtual Splint you can have a program called Floating Point create a proxy ID for both of them which enables you to use it without problems.
Posted on Mar 29, 2009
Action replay doesn't let me add codes in custom code list!!!!!
Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
Aug 03, 2009 | Datel Action Replay for Nintendo DS
I wiped all my games! HELP ME!!!!!!!!!!!!!!
i had the same prob
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
from codejunkies
Jun 13, 2009 | Datel Action Replay for Nintendo DS
Action Replay code manager wont read me action replay
Your replay needs re-setting....
You can tell if it needs re-setting by...;
Jun 08, 2009 | Nintendo DS Lite Console
Action Replay code manager won't recognize DS
Go here: http://www.datelcustomerservice.com/product_help/NDS_ARDS_Help.html#WinXP. Scroll down to "Q: My Action Replay is not being recognized by the Code Manager Software, it just says waiting for DS in the left window; what do I do?" click that and read & follow the steps carefully.
May 30, 2009 | Datel Action Replay for Nintendo DS
Action Replay deleted all of the cheats for Nintendo DS
you can reconnect your ds+AR and you can put the codes back on there by clicking and draging one of codes list from codejunkies.com if you have your Action Replay Code Manager installed, which should come on a disc you bought with your AR
May 29, 2009 | Datel Action Replay for Nintendo DS
Action Replay DS has deleted avery single cheat code it came with
source codejunkies
May 13, 2009 | Datel Action Replay for Nintendo DS
Action Replay Code Manager Help
when i did this i had the same problem but while it does recognise it for just a little whyle, quickly press quick update and wait for the bar to go from one side to the other and then wait for it to
update your action replay from a to z and then it should recognise it after that but if not just do it again but dont push the wire in to far ok
Apr 12, 2009 | Nintendo DS Lite Console
My Ds Action Replay Went BLANK!
i have had a similar prob it wiped all the games andm then i could not put more on because it went multi coloured when i tried so i hap to reset the entire thing to do so(source codejunkies):
copyed from code junkies
Mar 20, 2009 | Datel Action Replay for Nintendo DS
DS Lite and Action Replay Issues
First of all, make sure your DS isn't connected to the computer at all, and try the fix again (the "A+B+SELECT+START" thing that you know), THEN plug in your computer (let go of the buttons at then menu screen, then plug it in). DON'T hit the quick update button on the code manager and select the empty code-list and delete everything in there again (The one on your DS). Select a game in your code-list on the bottom right (I chose Pokemon Diamond) and drag to the DS window (left).
Now try to add something to the code-list on your DS (the left window) And it should allow you to write to your DS. After the Reset, I had no problems re-adding games to my Action Replay after following the steps exactly. If you have your DS plugged in before you did the reset thing, that may be the problem. Make sure you do the software update (the top right button on the code manager on the computer) just to make sure you're up to date.
Aug 23, 2008 | Nintendo DS Lite Console
Action Replay DS - "Load Failed" Error
Have you tried re-installing the Action Replay Code Manager through the disc? I find that re-installation works for most computer programs when the first-time-installation fails. Just choose the most recommended settings (don't do manual stuff) and try again. If it still does not work:
-Check to see if your internet is connected properly
-Check the disc for any scratches; Scratches on the top of the disc are LETHAL to memory!
Jul 21, 2008 | Nintendo DS Lite Console
Datel Action Replay for Nintendo DS Logo
1,288 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
