Question about Panasonic CT-32D11 32" TV
Panasonic CT-32D11 TV
The screen is totally black with a 6" wide horizontal gray area and in the middle of the gray area there is a bright thin horizontal line. No sound. When I use the remote part of the menu will appear and the words are upside down. What might the problem be and what should I do?
  • 398 Answers
Your vertical output IC has stopped working. This is usually caused by the solder joints cracking loose and the IC will either short out inside or just stop working. Sometimes a small capacitor next to the IC, called the pump-up cap, will go bad and cause the IC to fail. In any case, the vertical output IC should be resoldered or replaced and all circuits checked by someone experienced in repairing TV's.
Posted on Aug 05, 2007
SOURCE:
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Sides of the picture are encroaching and making watching bothersome. Can this be adjusted by the consumer in some way?
this is most likely a problem with a capacitor going back in the horizontal stage of the tv's circuit. if the tv has a horizontal knob on the front somwhere you may be able to expand the width of the picture for while but eventually the problem will continue in which case if you know someone who knows how to replace electronic components the bad capacitor(s) will need to be replaced or the tv will have to be replaced.
May 31, 2009 | Panasonic CT-32D11 32" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
Panasonic CT-32D11 32" TV Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
