Question about RIM BlackBerry Pearl 8100
My Blackberry pearl will not charge via wall outlet charger or USB (or any other charger). The battery is fine as I can charge it in my other blackberry and I have to keep switching batteries back and forth. I've tried cleaning contacts with an eraser to no avail. Any ideas?
My pearl wont charge threw my wall but it will slightly & slowly charge threw my xbox 360 and laptop..... anyway of gettin it fixed... oh and ive had the phone for 2 long all warrantys have xpired
Posted on Dec 11, 2009
    Sergeant:
    Champion:
  • 232 Answers
The terminals would have to be faulty .
Check the contacts first , turn your phone off before removing the battery and make sure to have all the contacts pins intact .
you may have also a bad circuit but it sounds more like contact problem to me
Posted on Sep 26, 2009
    Problem Solver:
  • 9 Answers
Your most likely going to have to buy a new phone my blackberry pearl did the same thing and it was because something was wrong with the inside of the charger port mine would say it was charging for all of about 5 seconds then disappear or you can go to your phone company and tell them that it is messed up and ask them for more batteries. good luck hope i helped :)
Posted on Aug 04, 2009
I cant get my blackberry pearl to charge!
Yes I would take it back to your purchase place for repair or replacement. Only other way to charge is by using an external battery charger: http://www.amazon.com/External-Battery-Charger-Original-Blackberry/dp/B001MEV8LI/ref=sr_1_7?ie=UTF8&s=wireless&qid=1263336321&sr=8-7
Jan 11, 2010 | RIM BlackBerry Pearl 8100
Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
Jan 05, 2010 | Nikon Coolpix S210 Digital Camera
My usb port is damaged on my blackberry can not charge it how do I charge the battery? I cant charge it via the usb port which is needed for almost everything. is there another way to charge my blackberry...
The only thing you can do is use another BB to charge up the battery, and then swap batteries. Someone usually has a broken BB (screen dark, sound stopped working etc) which they will give you for free..
Jan 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
When I plug my phone via the charger into the outlet, the phones lights up and acknowledges it is charging. Then after a few minutes it goes dark again which is normal. However then occassionally it will...
There might be some problem with the charger or with the Battery, kindly remove the battery and check with other handheld if it is working fine then there is a problem with the charger and you need to walk into the service center.
Oct 13, 2009 | RIM BlackBerry Pearl 8100
8320 curve battery in not charging through any medium.
i have the same problem, the solution is to go to BlackBerry Service Centre or buy external charging device for battery.
Oct 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Aug 20, 2009 | RIM Blackberry Curve 8300
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
Blacberry pearl niot charging
I have a new blackberry pearl, have had it two weeks and today it will not charge no matter which charger I use so I don't know what the deal is.
Jun 10, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl not holding charge
Sorry to say, I encountered this same problem. I checked the prongs, used different power cords, different outlets, usb cord, and different batteries and yet still nothing worked. The only remedy to this situation is replacing the phone.
Apr 22, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
290 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
