Question about Samsung Televison & Video
Hg22ea470 Can't auto tune
What buttons on the remote do u press to auto tune
There won't be a direct button to Auto Tune. That would be too risky. What happens if you accidentally press it halfway through an important program.
The tuning and other set up functions are accessed via the TV menus. There's probably a button called something like Menu or Setup. Once you press that you'll see all the options. Use the navigation and OK/Select/Enter key and the Exit/Back key for navigation.
Somewhere in your TVs menus there will be a section for tuning. Within that there will be at least two options - Manual Tuning and Auto Tuning.
Hope this helps
Sep 18, 2014 | Televison & Video
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
What buttons do I use to auto tune my soniq tv 42"
Hope this helps.
How to auto tune a 42" soniq tv for the new free
Hope this helps..
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
AUTO TUNING WONT RUN
Check and replace its main system control memory IC. If this IC is faulty, auto tuning will not work, or, the TV will store any received channels. If the TV do not tune into channels too, the AGC voltage to its tuner, and tuner itself should be checked.
May 27, 2013 | TCL L32D20
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
Tuning a sony trinitron tv
Most of the sony TV's comes with an auto tuning facility and all your need is ensure that the RF inout/cable TV or antennae is plugged into before the auto tuning is activated.
The auto tuning is available inthe older models on the set and in the newer models on the remote control. Choose program menu , tuning, auto mode.
Also you can search inthe manual mode individually and preset the channels position to your convenience such as news channels together, movies together etc.
Sep 21, 2010 | Televison & Video
Hi I need to make tune up to automatic transmision for Mitsubishi Outlander 2003 but the auto parts told me this auto don't need this tune up
Engines get tuned up. Transmissions get the filter and fluid changed. The auto parts store guy misunderstood what you want to do.
Oct 09, 2009 | 2004 Mitsubishi Endeavor
Difficulty re-tuning my KD28DL10U in set-up menu
Difficulty re-tuning my sony KD28DL10U in set-up menu Auto tune is greyed out. Lost ch5 and do not have itv 3&4
Oct 03, 2009 | Sony Televison & Video
Televison & Video Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
