Question about Frigidaire ATF6000ES Front Load Washer
The glass broke during spin - Frigidaire ATF6000ES Front Load Washer
  • 240 Answers
Metal objects in wash? replace glass
Posted on Mar 16, 2009
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
701clps
The shocks in the bottom of the washer are either broke or came off remove the front lower panel and u can access them
Jul 21, 2014 | Washing Machines
Glass Window Shattered During Wash
Maybe the internal drum was rocking due to an unbalance with the weight of the towels that it has knocked onto the door causing the glass to break. only thing i can think of , glass shouldn't break unless its hit or there is a large amount of temperature change, adding cold water to a hot glass for instance.
Mar 24, 2014 | Bosch WFVC3300 Washer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Front glass window seems loose
When the machine is spinning, place your hand gently against the glass and check for a vibration. Do not push on the glass.
This is to check and see if the vibration is from the door or from somewhere else.
The front door comes apart. Disassemble the door and check the seal where the glass sits. If this seal is worn or out of place it will allow the glass to rattle against the rear panel. When the machine is spinning, place your hand gently against the glass and check for a vibration. Do not push on the glass
Jan 12, 2008 | Bosch WFMC 3200 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
