Question about Whirlpool GW399LXUS Stainless Steel Gas Range
Touchpad replacement GW399LXUS04 - Whirlpool GW399LXUS Stainless Steel Gas Range
The "0" and "9" buttons have suddenly decided to stop working. Is there any quick troubleshooting tips that might fix them before deciding I need the whole Control Pad replaced?
Disassemble and clean with alcohol and q tips the contact areas under the "0" and "9" buttons respectively. You can also increase their conductivity by using a #2 lead pencil and rubbing the lead on the affected areas.
Sep 05, 2015 | Stainless Kitchen Ranges
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Lo scroll touchpad non funziona samsung p530
google translated
touchpad scroll does not work samsung
Feb 07, 2013 | Samsung P530 Notebook
Touchpad won't work
What's wrong with the touchpad? Rather than fix it if it is broken just replace it. In fact you can replace the whole palmrest which includes the touchpad that does not cost a lot.
Maybe you turned the touch pad off.
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Maybe you just need to reinstall the touchpad drivers.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
May 13, 2012 | Toshiba Satellite M65-S9092 PC Notebook
My mouse pad stopped working on my Compaq Presario 2200.
if this is the touchpad, try to reinstall the touchpad driver. You can uninstall it through the device manager while using an external mouse, then download the latest driver from your system manufacturer's web site. After that, make sure the touchpad is enabled and if this does not work, you may need a replacement touchpad, though you may also try system restore or OS reinstall.
Aug 31, 2010 | Computers & Internet
HP Pavilion DV1000 touchpad and keyboard freezes
sometimes its a hardware driver software and OS driver software conflict on touchpad. if after OS installation the touchpad is already detected, no need to install the touchpad driver. try disabling the touchpad driver you installed. hope this helps
May 30, 2009 | HP Pavilion dv1000 Notebook
Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
I hope the drink did not damage the touchpad.(it is heat senstive)
if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
Nov 13, 2008 | Dell F3534 Touchpad
HP NC6400 touchpad
Hi i am an ex HP employee
here are the steps
Remove the TouchPad Assembly
  1. Remove the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Lift the rear edge of the TouchPad assembly and remove it from the top cover.
  4. Disconnect the TouchPad cable from the system board.
  5. Remove the TouchPad assembly from the notebook.
Replace the the TouchPad Assembly
  1. Place the TouchPad assembly over the palm rest.
  2. Reconnect the TouchPad cable to the system board.
  3. Toe the front edge of the TouchPad assembly into the top cover and lower the rear edge into position until it snaps into place.
  4. Close the display panel and turn the notebook upside down.
  5. Replace the T8-9 mm screw that secures the TouchPad assembly to the base enclosure.
I hope it works out
Jun 04, 2008 | HP Compaq NC6400 Business Notebook
Whirlpool GW399LXUS Stainless Steel Gas Range Logo
48 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
