Question about Epson PowerLite 7300 Multimedia Projector
A red convergence problem (double image) on my Powerlite 7300
In "menu mode" without an input or source into my projector I see a double image (the second image seems to be in red) on the screen. The blue and green colors seem to sync up fine. Can this problem be fixed with the projector SM-ELP5300 software or can it be internally adjusted?? Thanks in advance, cross-eyed Jim
  • 32 Answers
SOURCE: Epson Powerlite 7300 Display Problem
Optical engine failure. Bad prizm.
Posted on Feb 13, 2008
Marrie
  • 563 Answers
SOURCE: Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Posted on Apr 17, 2008
SOURCE: greenish tint
Not sure if this is the solution, but I believe the color polarizer filters have been burned. I have a yellow haze circle on mine and I'm pretty sure that's the problem. In my case the blue filter is burned, leaving the red and green stronger yeilding a yellow blur.
Posted on Jan 04, 2009
  • 6 Answers
SOURCE: The color on my Epson
Two possible solutions:
1) The video mode is set to Component/RGB instead of VGA.
2) The cable you have may have a break inside of it.
Let me know if you find anything.
-Jeff
Posted on Mar 18, 2009
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
Green screen on VGA with Viewsonic PJD5122
VGA is separated analog signals in Red, Blue, and Green. Under normal cases, you'd be able to change the cable, source, or input port and resolve the issue. Unfortunately, if the green tint persists with all input ports on the projector (The two blue ones are Input, the black one is output. There is a potential that attaching input to the black output port could have caused the damage), different sources, and different cables, then it's likely a problem with the projector hardware itself and would require warranty service or otherwise repair or replacement of the projector. If you have an alternate way the projector can be attached, then try that (Such as SVideo), otherwise there may not be any good solution in this case short of checking the guts of the system.
Mar 28, 2014 | ViewSonic Office Equipment & Supplies
Projector image switches off when image gets super bright
Hi , what type of cable are you using for the video input source ? HDMI or RCA ? it very much sounds like a faulty cable or lose connection , would try that avenue first before anything else,
Mar 20, 2014 | Office Equipment & Supplies
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
I have a Sanyo projector that shows a completely blue image - I can see the computer image but it is completely blue - Whet I press the menu button the normal colours come up for the menu
it sounds like the wire you are using to connect your PC to projector is bad
if color is normal when menu comes up then it is not projector unless the input for your PC is bad
i would try new cable first since that would be cheapest
do other sources in other inputs work???
Mar 28, 2011 | Sanyo Office Equipment & Supplies
Have an infocus litepro 580, lamp and speakers works fine. Projector will only show the "infocus systems" opening display without changing to my video source. All cables are correctly in,...
Go into the settings menu of the projector and turn off the auto source function, then select the input that you are using.
if using a laptop you may have to simultaneously press your FN and relevant 'F' key to send the signal out to the projector. The 'F' key usually has an image of two side by side monitors or it says LCD/CRT. Wait a few seconds each time for the signal to be sent to the projector. Sometimes you may have to repeat this action 3 times to get the image on both your laptop and your projector.
good luck
Mar 08, 2011 | Office Equipment & Supplies
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Epson powerlite s4 projector is pink
Apr 01, 2009 | Epson PowerLite® S4 LCD Projector
PLV-Z2 AV System Menu locked on 1080i
If I understand your description correctly, when comparing it with my Z2, this is a function of the input type. If you have the input set to DVI and ANY digital source connected, the projector selects the mode that it is receiving and does not allow you to modify it. The options on this menu are only available when using an analog input. Try switching to any of the analog inputs and see if the option doesn't re-appear. It seemed strange to me too at first, but it makes sense because the digital input does not require "fine tuning" to convert it from analog to digital because it is already digital and therefore the signal itself skips this conversion step and the menu that goes with it.
Feb 25, 2008 | Sanyo PLV-Z2 Multimedia Projector
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Epson PowerLite 7300 Multimedia Projector Logo
187 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
