Question about Uniden Cordless Phone
I need to disable pulse dialing and activate touch tone Model 27928GE5-C cordless phone 2.4 Ghz
When the phone is off, try press flash/program button and then the tone/* button.
Posted on Jun 22, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
I have a GE cordless phone model # 26928GE2-D and would like to know how to change the setting from pulse to rotary dial
The phone is pre-set for touch-tone use. To set to tone or pulse dialing:
1. Press and hold the Program button until you hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the Program button again. You will hear a confirmation tone.
For more details, kindly download the instruction manual by clicking this link
You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Also, the manual has very small print, so kindly magnify it by using the "+" button in the Adobe PDF reader window.
Hope this solves your problem. Thanks for using FixYa
Mar 25, 2010 | Uniden Cordless Phone
Is this model pulse dial? We do not get touch
What model Uniden DECT 6.0 phone is "this model"?
Jan 25, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone went from touch tone to pulse. . .
Read the manual to reconfigure that option. (Look for Setup button on the phone) I can't guess what model you have. On older phones one could find a switch on the the phone to flip between Tone and Pulse.
Sorry I could not be of much help.
Sep 04, 2009 | Uniden Cordless Telephone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
440 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
