Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Is the bottom wash arm supose to move freely. It move about 6 inches and then sticks, Both arms were clogged and I seemed to have fixed with Vinegar
  • 423 Answers
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Posted on Mar 29, 2009
Dish washer does not drain. Checked for food being stuck anywhere. removed wash arm and plastic housing and checked for any type of blockage. Dishwasher hardly used.
Posted on Nov 17, 2009
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
During wash cycle of my Maytag Legacy SAV515DEWW, tub moves freely and after spin cycle, tub keeps spinning for a while.
Maytag has a drum brake located on the bottom of yor machine. You need to remove the brake and clean it up or perhaps replace the device.
Google Maytag washer drum brake for several "how to"sites
Nov 30, 2014 | Maytag Washing Machines
Top spray arm does not turn during wash or turns slightly..it is free of clogs and spins freely by hand
It will spin freely by hand, but needs to spray water out of the jets at the trailing edge of the arm. Check inside the arm for blockage and make sure that water is getting to the upper arm from the pump.
Feb 13, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Top wash arm does not move under water pressure,but moves freely by hand, leaves soap residue on top rack. not clogged and bottom works ok model # fdb750rcc
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
''ll';l;
Aug 19, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Rotors not turning during operation
Confusing..You say in one line Rotors not turning during operation. next line says
The top & bottom blades are able to move freely?
Il try & help anyway.1st the water level may not be high enough to load the the wash motor & spray water.2nd the dishes or cutlery may be hitting the arms.
May 30, 2010 | Zanussi 24 in. ZD686 Built-in Dishwasher
The bottom washes really well but the top hardly washed at all leaving even loose food on the dishes, glasses, etc. What's the problem?
Most likely there is debris in the washer arm or the arm is gummed up so it can not move freely
Oct 22, 2009 | Dishwashers
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
I have a Frigidaire Ultra Quiet Plus dishwasher. The top spray arm isn't spinning during wash. The bottom spins fine and I can spin the top freely by hand. It appears there is not enough water pressure...
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Oct 20, 2008 | Frigidaire Dishwashers
Bottom Washer Arm Problem
Hi Karen P The bottom arm ( well all arms really)is rotated by the water pressure created by the main pump. The bottom arm should spin freely when rotated by hand. If not, then the bush (or plastic bearing) may be worn or sticking. These parts are fairly inexpensive (at worst a new bottom arm will be required). Contact your local Maytag spares supplier and ask for a Bush repair kit for the bottom arm of your model. Regards
Aug 20, 2007 | Maytag DWU9962 Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
608 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
