Question about Mitsubishi VS-45607 45" Rear Projection Television
Picture is Rolling..stops after some warm-up
I own a VS45607 it's a great TV it started having a rolling picture about two months ago. The picture would not always roll if you turned the TV off/on a couple times. When you got it to stop rolling then it was dark, but got lighter after warming up. The picture stops rolling after the TV warms up a bit...MOST OF THE TIME. Now, it takes longer to get it to stop rolling. What can I do?
  • 1 more comment
  • boofis68 Jun 09, 2008
    mits 65,,,overheats and rolling screen,,,then shuts off,,,where is this regulator located and what does it look like?
  • Anonymous Aug 24, 2008
    same problem with same model. I leave the tv on all day for the dogs; probably shouldn't now! Although it is ten years old. After a month of intermittent rolling, now it's always rolling, with "interference lines" across the middle. Yikes-what to do...my Circuit City/ The Good Guys went out of business here and they had previously serviced it.
  • Anonymous Mar 16, 2014
    picture rolls and white lines until it warns up
  • 398 Answers
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Posted on Aug 05, 2007
  • 927 Answers
The cap's in that 9v circuit need to replaced also.
Posted on Sep 04, 2008
SOURCE:
Magnavox picture has started rolling.
You have a failing eeprom. The location on the board is IC002. The correct eeprom depends which microprocessor [IC001] and stereo decoder [IC1001] is used in your TV board. When removing old eeprom , insert a eight pin socket and solder into place. Now you may insert the new eeprom. This will be handy the next time you need to replace this IC the next time!
Jul 04, 2010 | Philips Magnavox 27MS343S 27" TV
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Mitsubishi TV picture rolling
Look on the back and see if you have an adjuster.(It should say
H-HOLD) Just turn it very slowly until the picture stops rolling,You can do this by watching the tv screen in a mirror.
Please rate this solution.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Rolling picture
Try replaceing capacitors C2C52 10uf 50V capacitor and also C2P05 100uf 16V capacitor. these are both on the signal board. It that doesnt correct the issue replace IC2P01 which is the 9volt regulator also located on the signal board. That should take care of your problem
Jun 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
676 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
