Question about Cuisinart Coffee Makers & Espresso Machines
Cuisinart coffee on demand
Coffee maker sounds like it wants to kick in, but no coffee is brewed and reservoir water doesn't go down. N
  • 8,596 Answers
There are a couple of possibilities. I would try an unconventional decalcifying process - let 1/2 a caraffe of distilled white vinegar and 1/2 caraffe water sit in the reservoir for a full hour with the coffeemaker unplugged. At the end of the hour, plug the coffeemaker back in and turn it on - once a small amount of vinegar and water brews through, turn the coffeemaker off. Let sit for an additional 20 minutes. Then turn the coffeemaker back on and let the rest of the vinegar/water brew thorugh.
If the machine doesn't take the vinegar/water at all, call Cuisinart and find out if your are still in-warranty. If you are, get the machine replaced. If you are out of warranty, you can remove the bottom of the coffeemaker (difficult), and look at the bottom - likely you will see a loose hose. You can get a Ace Hardware or True Value Hardware salesperson to find an adhesive that will put it back together, or get a generic replacement hose - original parts would not be available except by buying a broken Cuisinart in the same model.
My two cents.
-Tha Mp3 Doctor
Posted on Mar 12, 2009
Owned this coffee maker for 14 mos. At first you'd turn the brew switch and the brew cycle would start. Over time you'd turn the brew switch and it would take awhile. Now who knows when it will start.
Over time, Calcium will deposit on the tubes and containers which get in touch with water. Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
Jun 19, 2015 | Cuisinart DCC-2000 Coffee-on-Demand 12-cup...
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
Need to clean cuisinart 12 cup coffee on demand coffe pot. How do I clean?
Do you have the DCC-2000?
To delime a multi-cup coffee maker, mix white vinegar with water (1/3 vinegar and 2/3 water) and fill the water reservoir completely. Then turn the coffee maker on. Wait until the unit completes the "brewing" cycle and beeps 5 times. Turn off the coffee maker. Discard the liquid after the cycle. Then fill the reservoir with clean water and turn on again. When this cycle completes, again discard the liquid. Repeat the water rinse if you notice an odd taste to the coffee afterwards. (If the coffee maker still has deposits, repeat the vinegar cleaning cycle and rinse cycles.) There are commercial deliming products, mix them with water following the package directions.
The manual for the DCC-2000 is available as a link here: . The direct link to the manual is .
I hope this helps.
Jun 19, 2011 | Vacuums
Cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Jun 16, 2009 | Cuisinart Coffee on Demand 12-Cup...
DC2000 Cuisinart Coffee On Demand will not brew
on my dcc2000 when brewing on automatic timer it only brews a part of the reservoir . Say 2 or 3 cups out of the 6 I fill to.
Apr 14, 2009 | Cuisinart DCC-2000
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
204 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
