Question about Invicta 0861 Mens Sea Hunter Pro Diver Platinum Grey Watch
The bezel ring fell off the first day i had it.
How do I use the moveable outer numbered ring on the t49825dh?
The numbered bezel can be used by divers to measure elapsed time on their oxygen supply. Place the zero where the minute hand is now and you'll know when 20 or 30 minutes have passed when the minute hand reaches bezel number 20 or 30.
In the same way, you can use the bezel to tell when 30 minutes have passed on your parking meter if you simply put the 0 on the minute hand when you leave the car. When the minute hand reaches the 30 mark, a half hour will have passed.
Typically, the bezel only turns counterclockwise to keep the wearer from bumping and changing the elapsed time number. On some less expensive watches, the numbered bezel does not turn and is decorative only.
Oct 23, 2014 | Timex Tiex en T49825DH Expedition Military...
The bezel ring is stuck
These bezels sometimes get clogged with dust and dirt, it will need to be removed and cleaned, there is a small spring underneath so care must be taken so it is not lost while removing the bezel
Sep 28, 2013 | Swiss Army Wenger Watches
The black plastic ring, w/ white markings (bezel ?), that goes on the metal (dial) which moves around, fell off. Is this part avail., and if so, for how much ?
This part is called the bezel, you are correct. They are available to buy as a separate item for certain watches, but not all. You didn't mention what type of watch it was. Most major brands, like Rolex, Omega, Tag Heuer etc all sell bezels for their watches, brands though like Diesel, Rotory, Seiko etc, do not sell bezels as a stand alone item. Should you wish to let me know the make and model of the watch, I will see if I can obtain one, or failing that I will see if I have one that will fit.
Apr 24, 2010 | Casio Marine Gear AMW320D9EV Wrist Watch
I have an omega speedmaster and the bezel fell off I want to r
Any good quality SUPER GLUE will do the job. Apply to the case only and push the ring straight away onto it. Make it precise first time, as there will be no aligning possible afterwards. Rate me, please.
Apr 08, 2010 | Rolex Daytona 116528 Wrist Watch
I need a replacement-part of a bezel insert-ring for a Rolex
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Rolex Yacht-Master 16628 Wristwatch
A metal jewel fell off of the watch face and is loose on the dial
I suggest you take it to a watch shop and ask them to repair it for you.
It can be more difficult than it appears to remove and replace backs particularly.
Feb 25, 2010 | Watches
How can you tell if a watch received shock?
Hmmmm If the watch is still working then its probably okay. Did you get the crystal and bezel fixed yet? If not then please do so soon! Moisture will get into the movement and create rust and/or corrosion!
Obviously I cant see the watch but Movado watches usually use a plastic gasket to hold the crystal in. Most of the time those hold with no problems but occasionally they might not be placed in correctly. Movado will probably not cover that under warranty.
Jan 07, 2010 | Watches
Taking the glass from my watch
Rolex glasses are held in place by the bezel ( ring surrounding the glass ). Bezel must be lifted off first in case if the glass must be removed. Rolex bezels are friction fitted and are very tight. Usually special tools are used for bezel lifting, but in skilled hands the watchmakers knife can do the job as well (inserting the blade between the bezel and case and slowly prying up all athe way around).
In most cases the bezel still holds the glass when lifted off the case. To release the watch from bezel ring you will need a special press with dies as you will need it for refitting glass and bezel on to the case.
I would advice to find your nearest watch repair shop and ask for help, because without proper tools it is allmost impossible to remove and reset Rolex glasses without damaging them.
Do not forget to rate, please.
Jan 21, 2009 | Rolex Submariner 16618 Wristwatch
Rotating outer ring
It is primarily cosmetic - the bezel was originally designed for diving, military activities or similar where counting down time was critical. Before digital stopwatches etc were built into watches as a feature, what you did as a diver was turn the bezel to the time (say 30 minutes) of air you had left, then the minute hand would travel around the face to the position 0 on the bezel, telling you 30 minutes had passed. You often find compass directions, various job specific calculators etc on bezels also, but unless you need a stopwatch / time reminder and don't have that feature in the watch itself, then it is purely a tradition to include a rotating bezel. The original bezels would have the time markings going the opposite way to the watch face usually, however on many modern watches, they often go the same way, allowing you to see how much time has passed, rather than how much you have left. Hope this clears things up :)
Mar 31, 2007 | Fossil CH2332 Wrist Watch
Invicta 0861 Mens Sea Hunter Pro Diver Platinum Grey Watch Logo
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
