Siemens washing machine S19 36
Flashing F18
SOURCE: wf860
with my wt965a hotpoint ultima lcd fault code f 18 it was a reverse polarity on the main electric board of the house which means live & neutral are the wrong way round good luk dekka2
Posted on May 20, 2008
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Posted on Dec 24, 2009
  • 6277 Answers
SOURCE: Set machine to wash; Came home to discover machine
Bosch F18 can indicate a drain filter/drain pump problem so I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside. The smell COULD be coming from a jammed drain motor.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
SOURCE: Siemens s14-38 washing machine has
We have the same problem. How did you sort it?
Posted on May 09, 2011
  • 6277 Answers
SOURCE: F18 error message siemens washing
For most models- you do not say which yours is- Bosch's 'F18' states 'drainage (filter) problem.
I advise you read through these guidance notes and check the filter AND the operation of the drain pump itself- it could be jammed.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 12, 2011
F18 ERROR ON WASHING MACHINE
have you CHECKED the filter is clean
leave feed back
Jan 09, 2014 | Washing Machines
I was washing today and at the end of every wash tere was a code of f18 flashing on my screen .what should i do
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins.
Jan 06, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
My washing maschine says F18. What does that mean?
If you let me know the Make of the machine, I can tell you exactly what F18 code is and what needs to be done to repair it.
Dec 31, 2010 | Washing Machines
Washing machine will not spin or complete cycle. It has flashed up F18.
O need to know the brand and model to continue to help. Thanks
Dec 02, 2010 | Washing Machines
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
What do I do when My machine shows F18 as an indicator of a problem
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
thank u
rate me
Aug 23, 2009 | Bosch Washing Machines
Bosh Washing Machine F18 fault
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
