Question about KitchenAid Kitchen Ranges
Gas cooktop ignitor runs when stove is off.
Knobs are turned off but ignitor keeps running. It stops if I turn on a burner.
  • mcbowra Mar 13, 2009
    What is a spark switch? Easy to fix?
  • KitchenAid Master
  • 3,361 Answers
Defective spark switch. Could be one could be more than one.
Posted on Mar 13, 2009
  • steve
    steve Mar 13, 2009
    Each surface valve has one attached.
    You have to remove the front cover on the range that covers the surface valves.
    The switches are on each valve stem and have wires running from each one to the next one.
    Then you can unplug one at a time to see which one is bad.When you unplug one and it quits sparking, that is the bad one.
    Replace the bad one.
Two of my burners are clicking even when the stove is off. what should I do?
There is a switch that slides onto the shaft for each burner. When you turn the knob to a certain area it completes the circuit to the ignitor module. It sounds like you have a shorted switch. Unfortunately with most 'cooktops', these are not easy to get to.
It's also strange that only 2 are igniting, usually one module runs all the ignitors. When you turn one of the non-problem burners on, does it click when it supposed to and stop when it's supposed to?
The ignitors running constantly is annoying and may damage the module, but should not be dangerous unless you have other issues, ie., fuel leaks.
If you have access to basic hand tools and a multimeter I can walk you through the diagnosis.
Sep 15, 2011 | GE Profile JGP636 Gas Cooktop
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
The electrodes are ticking when we turn on the burners
THAT IS THE IGNITOR FOR THE GAS. TURN THE KNOB JUST BEYOND THE START POSITION AND IT SHOULD STOP. IF NOT UNPLUG THE STOVE AND FIND THE IGNITOR ON THE BURNER HEAD AND CLEAN IT WITH A SOFT TOOTHBRUSH. PLUG THE STOVE IN AND IT SHOULD STOP CLICKING
Aug 22, 2009 | GE JGP975SEKSS Stainless Steel Gas Cooktop
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
96 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
