Firstly as soon as I connect the MP3 player it shows USB connected. I downloaded music files.When I disconnected it from the USB, it turns OFF to not to turn ON. Also it just played the songs only once when the USB was plugged in. Since then it just shows USB connected and nothing else. By anychance has any one of you bought it from deals2buy.com thru google checkout.
music files will not open to play. LCD states no files when mp3 is turned on!music files will not open to play. LCD states no files when mp3 is turned on!
You can't post conmments that contain an email address.
Connect the Sansa to your computer using the supplied cable. Open up the operating system's explorer window. The Sansa will show as either a Sansa or a removable hard drive, depending on the USB mode. Either way, open it and you'll see a folder named "MUSIC". Open that. You can either delete entire albums or navigate into them and delete individual tracks.
You have to change the mode the player is in. See this guys tip posted here ---> Solve your MP3 Player Connection Problem. it is the best so I will just send you to his site.
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then add music this way and see if it is works: 1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
It sounds like there is a problem with the firmware...call sandisk and have them do a firmware upgrade on the device...once you do that it should fix the problems you are having right [email protected]
I dont usually mess around with real player when you dl or put your music on your computer put a shared folder in there and put all your music in there and then when you connect your mp3 player go to your shared folder and right click on the song when it comes up go to send to and it will give you a list it will say what ever you mp3 player is named and if you click that it will put your music on your mp3 player
and if you couyld upgrade to at least a widows xp
~Grim
(FOUND THIS SOLOUTION ON AFTERDAWN.COM)
The problem is that this player have 2 standards for connecting to PC. One is MSC and other is MTP. Each one have different directories structure. If you put music when your player is connected as MSC, when you will conect as MTP you'll be not able to see the files uploaded previous. The same case is available when you write music files as MTP=> you can't see these files in MSC mode. So, set USB mode of your Sansa as MCS, power off, put hold switch to lock and connect to PC. You will see 3 directories: Audible, Records and Config (or something like that). See if your "invisible" music files are here. If they aren't connect as MTP. To connect as MTP: set USB mode to auto, shut down Sansa mp3 player, put hold switch to unlock and connect to PC. You will see only 2 directories now. Media and "something" (I can't remember now). Look for your "invisible" files and do what you want. MTP mode is for use with newer PC's. I advice you to use MCS mode all the time because is compatible with any PC (old or new). Good luck!
can't find a driver
I can't open my write files
It showed mp3 connected and it dose nothing else.
