Question about Garmin nuvi 350 GPS Receiver
My GPS will come on, but that is all
It does not matter whether it is on the charger or not. All I get is the Garmin logo and then blackout. The first problem occurred when I could not type in any state other than mine. The next problem was would not receive address, and not total black out.
    Top Expert:
  • Garmin Master
  • 77,499 Answers
You have a hard fault in the logic circuit of the main board, I suggest u contact Garmin customer suppor at myGarmin.com, they have an exchange program and have been know to do this with a very small charge to you if not free.
Posted on Mar 12, 2009
  • 583 Answers
It sounds like a gps battery problem,replace the battery to solve the problem
Gamin nuvi 1450 wonot start and the gamin express cannot recognize it
Your Nuvi has to boot past the Garmin logo to the main screen before it can be recognized by your PC. Is the unit dead? The Nuvi 14xx series is well known for its problem with the rear USB port coming loose. This will prevent the unit from receiving power from the external charger and will prevent the battery from being charged. If the unit goes into a boot-up loop, displaying the Garmin logo then shuts down, this is often caused by corrupted files, such as a map or bad firmware update. See these two links for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Nov 01, 2014 | Garmin nuvi GPS
My garmin 1410 sat navi won't switch on
Most likely, your USB port is loose. This is a common problem with this model. The port needs resoldered and reinforced. When the port is loose, you will not be able to send power to the GPS and charge the battery. Please see this link for more info:
Jan 28, 2014 | Garmin Nuvi 1410 Car GPS Receiver
When resetting garmin 660 by holding reset for 2 hr 30 min, does it matter whether it is on or off or plugged into charger?
hi jeff,
im not sure why your holding the power button for 2.5 hours, but any reset should be done while unplugged
now, with the unit off, press and hold the lower left corner of the screen...keep holding ti while you hit the power button to turn it on...keep holding it till you see the screen that asks if you really want to delete all data (this will erase you saved info) select yes the follow the onscreen instructions.
Sep 11, 2011 | Garmin Nuvi 660 GPS Receiver
I've a garmin 1490, it's not possible to start a hard reset. The logo garmin is on the screen until battery is off.
Have you tried holding the power button for more than 20 secs - or after draining the battery and restarting on charger holding the lower right screen corner for at least 20 seconds?
Jul 04, 2011 | Garmin nuvi 1490T GPS Receiver
Plugged in my Garmin 205 this morning and all the screen will display is the GARMIN logo. How do I get it repaired?
hold your thamb finger at right/bottom cornner of LCD screen, then plug in car charger. unit will reset to factory mode. try it.
Mar 18, 2011 | Garmin nuvi 205W GPS Receiver
When I plug the gps into the charger a computer picture shows up and I can't get it on any other screen. What's the matter?
Did you recently purchase that charger?
This usually happens when the charger is not compatible with the unit. or you could be using a non-Garmin charger. There are some "store-brand" chargers that work well, and some do not. Store brand Charger are made to be Universal. To fit multiple devices and maximize profits. You want a Garmin Specific Charger, and here is the logic why...
The reason behind it:
1. The Garmin USB Cable that you connect to your computer has a special 4-pin configuration telling the GPS that is is connected to a computer. This is the configuration most "generic" chargers use to maximize device compatibility.
2. The Garmin Car Charger has a different pin configuration with 2 less pins, giving it only positive ( + ) and Negative ( - ) to charge the GPS.
When the GPS receives the 4 pin, which is also found in a "Motorola" Cell phone charger, it will automatically sense that it is connected to a computer.
Long winded, but I wanted to explain why. Simple fix, Just go get a new charger and make sure it's Garmin compatible.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 775 GPS Receiver: My Garmin nuvi 775 will come on with the Garmin lo...
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 03, 2010 | GPS
GPS will not come on
I have the same model. When I had a problem I called customer service. They linked w/ my computer (nuvi was plugged into it) and fixed the problem! Give it a try. They are very nice.
1-800-800-1020
Apr 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
