Question about Kenmore Series 70 Washer Motor 387780
Kenmore 70 series washer parts diagram
Will not agitate
catriver
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Posted on Apr 27, 2007
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
  • 249 Answers
SOURCE: Kenmore 70 series washer will not drain
sounds like the timer to me
Posted on Jun 16, 2009
honeymokey
  • 3113 Answers
SOURCE: Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
Dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Nov 06, 2009 | Kenmore Washing Machines
Kenmore Series 70 top load barely agitates....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series barely agitates and makes a clicking sound
What u have just described are failed agitator pawls/dogs, relatively easy fix. The repair comes as a kit. Most appliance repair houses will have the kit, if not www.searspartsdirect.com will have them
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Washer Motor 387780 Logo
630 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
