Question about Kitchen Appliances - Others
Kenwood TT 990 2 slice brushed steel Toaster
Which type screw driver is used for bottom opening
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 37 Answers
SOURCE: wiring diagram needed for 3 slice dualit model auto 3
get it at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Posted on Nov 20, 2008
SOURCE: 4-slice egg & muffin toaster
On my fourth one now...love the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
Posted on Jul 28, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
Toastess -TT 215P 2 slice toaster
if you can open it up the thing that holds the tab down could have been used up already.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Toastess TT-215P 2-Slice Toaster
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
How to take bottom off a cuisinart toaster model CPT-40
There should 4-6 screws to loosen. You may have to ring right type of head that will take it off.
Jan 25, 2013 | KitchenAid KTT340 2-Slice Toaster
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
UNPLUG THE TOASTER
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
Where do you buy the special screw driver to take the bottom ff the 44336 toaster as the toaster wont stay down on that side?
Well, I don't have that type of toaster. What do the screws look like? If they look kind of like allen but an allen wrench will not work, they would be TORX.
Feb 03, 2011 | Morphy Richards 44051 4-Slice Toaster
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Removing bottom cover to access fuse etc - toaster not working
Hi.. the screws on mine are pozidrive (plus sign shaped slots).. what do yours look like?
What's your toaster problem?
Dec 02, 2008 | Breville CT20 Retro Classic 2-Slice...
The level of the toaster doesn't lock
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Jul 17, 2006 | Toastess TT-415P 4-Slice Toaster
Kitchen Appliances - Others Logo
56 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
