Question about Kitchen Appliances - Others
Kenwood TT 990 2 slice brushed steel Toaster
Start tosting the handile is not stay down
5 Suggested Answers
suben
  • 214 Answers
SOURCE: Toastess -TT 215P 2 slice toaster
just check the clip that locks the toaster.if not repairable manually you have to replace it
Posted on Sep 09, 2008
espressonist
  • 1711 Answers
SOURCE: I have a 4 slice
The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook.
So the most frequent problem with elector-magnet is due to the heat some wire or springs become loose so the electro-magnet is not working properly so it does not stay down.
Another reason that electro-magnet not work properly is due to bread remaining does not leave the lector-magnet contacts to contact. You should clean between where the metal of the Electrical contact meet each other.
Posted on Sep 15, 2010
  • 1583 Answers
SOURCE: 4 slice toaster when pressed
Try cleaning the bread crumbs out of it. If you get enough piled up under the latch mechanism, you can't push it down far enough to engage it.
You may be able to do an adequate job by opening the bottom cover - most toasters are made so it's easily removed for this very purpose. If not, you'll need to pull off the knobs and remove screws so you can take off the top cover. Be careful not to touch the heater wires with any tools - after they've been used a while they become rather brittle and break easily, and even a scratch can cause them to erode and fail. I assume you know to unplug the toaster before working on it.
Posted on Jan 06, 2011
SOURCE: toaster latch does not stay
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Posted on Mar 03, 2012
The door on my toaster oven will not stay shut can I order a new spring?
sorry we are not the manufacturer or RIVAl toaster ovens . we do not know .
Jun 26, 2016 | Rival "CO602 6-Slice Toaster Oven Pizza...
if you can open it up the thing that holds the tab down could have been used up already.
tnx 4 using fixya.
drcool
Sep 09, 2008 | Toastess TT-215P 2-Slice Toaster
After 4 toasters in 2 years this one will not stay down when u need to make toast
All you can do is make sure the bread crumbs have been cleaned out and are not jamming up the works, they are not worth repairs. better to buy a new one . number 5 coming up?.
Jul 09, 2015 | GOURMET LIVING 4 Slice Toaster Stainless...
Toaster wont stay down
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
Jan 12, 2015 | Breville Vtt002 Polished Stainless Steel 4...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
6331 will not stay down
I have the 4-slice oster, but I bet the control mechanism is the same. When you take it apart you will see a small steel bar held by two plastic fingers. When you push the lever down the steel bar moves down and contacts a small square electromagnet. The electromagnet holds the lever down during toasting and releases the lever when done. On mine there was a compressed layer of bread crumbs covering the electromagnet. Cleaned it off and now it works again.
To take the toaster apart, pull the down lever straight out and then unfasten the screws on the bottom base (5 on mine) and pull the top off carefully. There are wires connecting the control face to the base, but they have enough slack to let you separate the top/bottom and access the mechanism.
Nov 24, 2009 | Oster 6307 / 6309 2-Slice Toaster
Our toaster stopped working a little while ago, but it is outside the (presumably) one year warranty period. It's a 4 slice, soft touch black toaster, cost about £75, I think it is this model. It only...
remove from the electricity supply
remove crumb tray,
remove bottom 4 os 6 screws.
at the bottom of the toaster there is what liooks like a flat fish hook that engages with the handle when you push the handle down to start toasting. clean around this and try to get it to engage when you push the handle down, it wont stay down unless the electricity is connected but dont plug it in as you will probably kill your self!!
put it back together abd try it
if it does not work 4 slice toaster from Tesco £9.99
Nov 09, 2009 | Dualit 45375 4-Slice Toaster
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Toaster will not stay down in toast position
uh, don't think there's a good chance, you could try to send toaster in for repair, but buying a new toaster is probably cheaper.
Nov 24, 2008 | Back to Basics TEM-500 Egg & Muffin...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
