Question about Microwave Ovens
Ge jnm1541dn1bb microwave has power display is working keypad is not responding
rickzilla
  • 706 Answers
SOURCE: GE microwave f3 code
You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/model-display.php
If you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Posted on Sep 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave - Keypad (Maytag MMV5156AAQ Over the Range )
Yes.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 26, 2008
techcrazy
  • 72 Answers
SOURCE: Microwave does not work
please dont forget to rate me on this issue...
Posted on Feb 02, 2009
SOURCE: keypad on the microwave doesn't work
well if you find out that your microwave keypad is not working, like those numbers or letters are not working, there's a 16 or 8 plug cords wire attach to the keypad and the motherboard.you need to clean that with normal water temperture.than dry it for about 10-20 minutes.
I garintie you it will work.
Posted on May 13, 2009
Richie_asg1
  • 1036 Answers
SOURCE: GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Posted on Aug 20, 2009
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave (model# JNM1541DN1BB) is giving me a message; service may be needed keypad shortage. Question 1 how can I fix it myself? Question 2 why did my microwave go out and how can I keep it from...
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad shorted on JNM1541DN1BB micowave oven. Need new keypad. where can I get one?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 21, 2011 | General Electric Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Touchpad doesn't work on ge model #jvm1540sn1ss
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
May 24, 2010 | GE Spacemaker JVM1540 Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
PF ?
Not actually dead, just apparently unresponsive.
PF means power failure. It either got reset or unplugged, etc.
If it's not responding to the keys, then you likely have a shorted keypad or trouble on the control board.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JES1238 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
