Question about Legacy Audio LA1030 Car Audio Amplifier
LEGACY AMP LA1030 RED PROTECTION LIGHT COMING ON
I HAVE A LEGACY LA 1030 AMP WHICH KEEPS GOING INTO PROTECT WHAT IS WRONG WITH IT+CAN IT BE FIXED?
AND IF SO WHAT DO I NEED TO REPAIR IT?
  • 1 more comment
  • Eric May 09, 2009
    im having the same problem, its the Legacy LA-1030 1000 Watt 4ch Amp and it has the option to bridge each 2 channels (so you end up with a 2 channel amp) and i have 1 4Ohm sub bridged across channels 1 and 2 and channels 3 and 4 are empty when it starts pushing the subs its not clipping or anything, but it goes on protect. whjat do I do to fix this because to get a new amp is about $350 which i dont have for car audio right now but i would really like to keep my system.
    please help.
  • Perry Babin May 11, 2010
    If it goes into protect with no speaker wires connected to the speaker terminals and no RCAs plugged in, it likely has shorted output transistors. Read through the following page if you want to try to repair it yourself. Let me know if you have any other questions.
    Basic Amp Repair Primer
  • soundwave77 May 11, 2010
    How many subs is this amp running? and what is the wattage off the subs and amp
Jexx
  • 148 Answers
SOURCE: amp shutting off going into protection mode
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
  • 631 Answers
SOURCE: legacy amp in protect mode
What was the part number on the transistor you replaced?
Posted on Dec 15, 2007
  • 631 Answers
SOURCE: Amp no longer turning on
Do the speakers push out or pull in when power is applied?
If not, how did you determine that is has DC on the speaker outputs?
Posted on Oct 05, 2008
  • 77 Answers
SOURCE: 600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Posted on Feb 12, 2009
  • 1348 Answers
SOURCE: LA-1030 Protect Mode
you have an unloaded channel,so the voltage is exceeding what the protect circuit is supposed to see.you have to connect an 8 ohm resistor across the output of the unused channel.
do not drive a signal into it or you will smoke the resistor.
a 10 watt will do ok with zero signal input
Posted on May 23, 2009
How much is a LA 1030 LEGACY amplifier?
It is old, so cheap secondhand. I found one for 40 GBP.
http://retrorides.proboards.com/thread/54783/legacy-la1030-1000w-price-blackpool
There are a number of better Legacy amps on eBay.
Legacy Car Audio Amplifier
Jan 17, 2016 | Legacy Car Audio & Video
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Protect light is on ,no sound?
Make sure you have a good ground connection. The ground wire should be solidly connected to the vehicle chassis in a paint-free location. If the ground is connected badly, the protect light will come on.
Mar 08, 2011 | Legacy Audio Legacy - Red Series: 2...
My amp keeps going off on protection mode as soon as the bass starts bumping
check powers and earth, unplug sub and crank it up see if it still goes into protect if it doesnt the sub is too much load for that amp and could have damaged the amp, if it still does it then its a fault in the amp or power problem make sure you have good thickness 4gauge and good earth
Apr 26, 2010 | Legacy Audio American Legacy II LA290 Car...
Protect Mode
Your probably not pusing enough wattage to the amp. Look into buying a capacitor for your set up. and you may need to run a thicker guage wire to your amp.
Jun 01, 2009 | Legacy Audio LA1030 Car Audio Amplifier
May 23, 2009 | Legacy Audio LA1030 Car Audio Amplifier
Power light turns from green to red protect mode and then there is no sound coming from my speakers
there are 2 reasons for it to be going into protect mode 1 is heat 2 is the load on it. if it is going into protect mode soon after it starts there is a problem with the speaker. if it is after it has been on for a while it is that the amp itself is overheating. hope this answers your question
Apr 27, 2009 | SPL Audio Phantom DK2-1000 Car Amp
Oct 04, 2008 | Legacy Audio LA1030 Car Audio Amplifier
Amp shutting off going into protection mode
Aug 14, 2006 | Legacy Audio American Legacy II LA690 Car...
Legacy Audio LA1030 Car Audio Amplifier Logo
578 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
