Question about Nikon Speedlight SB-800 TTL Flash
I can't figure out how to use my SB800 off camera with the D80 in command mode.
  • Tami G Mar 13, 2009
    Thank you Bigevy for responding. I want to use my SB800 off my camera. Thought I could use it in command mode to trigger the SB800 off camera. I do have a 3ft coiled cord that I can use with a braket and can fire the flash off that, but what I was wanting was to mount my flash on a stand further away from me. Trying to learn more lighting technique. I have found the DC-IN connector for optional EH-5 AC adapter, Video Connector and Remote cord connector on my camera. I read in the manual that Commander mode: Use the built-in-flash as a master flash controlling one or more remote optional SB800 using wireless lighting. Just a bit overwhelming for me and need some help. I have no issues using sync cord, if I could figure even that out. I have been reading for hours trying to educate myself and getting no where.
  • Richard Evans
    Richard Evans May 11, 2010
    You are wishing to use the flash off of the camera and still get the camera to fire the flash upon taking your photo. Does your D80 comes with a pc synch socket? Does your camera have a flip up flash? Have you tried connect a hot shoe slave to the flash that will trigger with your on camera flash. You may need to set your flash and camera to manual mode in order to adjust your exposure. Some manufactures make a coiled synch cord that you can remove the flash and still use the cameras programing to fire the flash. Not sure what command mode controls sounds like it is an all encompassing exposure control system the camera uses. Unless you have a dedicated cord that comes from the manufacture you may not be able to remove the flash form the camera and use the camera in command mode. Almost all cameras can use any flash in manual mode tho.
  • 4 Answers
You can purchase a simple hot shoe mount slave or a pc corded slave. Do you know what a slave is? Most cameras have a flip flash on the camera. You can use this to fire your off camera flash. Most flip flashes are so low in power as compared to your SB800 that the flip flash will cause very little exposure effect to the image. Now there are things to consider, such as if you are outside in bright light a slave has more trouble detecting a flash. If you are indoors you need to at least have the off camera falsh localised to the flip flash and the slave in direct view of the flash. Some slaves are more sensitive than others. the great thing is with digital you can experiment all you want. Back in the day using film was costly, a lot of bracketing and guessing and time consuming. Why do you want the flash off the camera? What is your subject? I have usually found a bounce card on the flash or off a ceiling or wall effective for people. If you are lighting an indoor scene it is understandable to use off camera lighting.
Posted on Mar 16, 2009
How do you turn off automatic flash manually on Nikon d80?
Assuming you're in one of the point&shoot modes (any mode other than the PSAM modes), press and hold the flash button on the front of the camera and turn the main command dial on the back to cycle through the available flash modes. To turn flash off, select the lightning bolt in a circle with a slash through it.
In the PSAM modes the flash will not pop up on its own.
Aug 22, 2010 | Nikon D80 Digital Camera with 18-135mm...
Inadvertanly set delay and can't figure out how to reverse it.
Are you speaking of "Exp. Delay mode"? That is found in Custom Settings Menu number 31. Page 99 in the D80 manual.
Jul 30, 2010 | Nikon D80 Digital Camera with 18-135mm...
Inadvertanly set delay and can't figure out how to get it back to the original setting.
Repeatedly press the shooting mode button on the upper-right side of the camera (marked with overlapping rectangles) to select the desired shooting mode. If that doesn't work, hold down the button and turn the main command dial (on the back) to cycle through the modes.
The available modes are Single frame (letter "S" in a rectangle), Continuous (overlapping rectangles), Self-timer (one-armed clock), Delayed remote (self-timer above remote), and Quick-response remote (remote).
I got a remote for my D80 how do i get it to work?
Set the Release mode on the camera to one of the remote modes by holding down the release mode button on the right of the camera (the one with the remote and the clock-like self-timer icons) and turning the command dial on the back of the camera. The two choices are Quick-response, where the camera takes a picture when you press the button on the remote, and Delayed-response, where the camera waits two seconds while you hide the remote behind your back before taking a picture.
Look in the camera manual under "Choosing a Shooting Mode" and "Using a Remote Control". They are on pages 36 and 38 of my copy of the D80 manual, yours may differ.
Jan 20, 2010 | Nikon D80 Digital Camera with 18-135mm...
I was using the D80 with an SB-800 Speedlight and at one point the buit in flash popped up. I now cannot get the built in flash to lock in the down position.
This must be because the SB800 was not seated in properly or was turned off when you used the cam.
Use one of the manual settings (A or S) and you should be able to keep the built in flash down (unless it was physically damaged that u need to bring it to the repair shop)
Dec 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
On playback screen of my nikon d80..
When viewing the images you've shot, spin the sub-command knob (front right of camera) to change the photo information you will see. There are a few modes so keep spinning the knob until you find the viewing mode you prefer.
Apr 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
No iTTL mode (or TTL mode) in SB 800 synced with cord to D300
Bingo! That's an X-sync cable, only for firing the flash, syncing it withe shutter - carries out no auto features or communication with the camera.
Don't waste your money on another cable the same. There is no TTL light measuring features with an X-sync cable.
You can, however, get the proper 'off-the-camera' TTL syncing cable either from Nikon or a 3rd party provider. This proper TTL cable can cost a fair bit, I don't know exactly but thinking from $40-$50 to $80'odd.
Shop around, buy from a store where you have the face-to-face enquiry and a return facility if 'they' get it wrong.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 04, 2009 | Nikon Speedlight SB-800 TTL Flash
The flash won't turn on
what kind of flash ? SB800 ?Sb600 ?
or are you using compact..if you're using compact,I guess you'll be needing Manual mode and tweek something on the setting menu.
Jan 31, 2009 | Kodak EasyShare C763 Digital Camera
I Have a Nikon d80 with a sb800 speedlight
CAMERA ON P , FLASH ON TTL , AND LENSE ON F22
WAIT FOR THE RED LIGHT ON FLASH , GOOD MEMORY CARD AND IT SHOULD WORK .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Nov 15, 2008 | Nikon Speedlight SB-800 TTL Flash
How do I activate the Nikon ML-L3 remote for the nikon D80 camera?
Set the camera's release mode to one of the remote modes by pressing the release mode button next to the top panel LCD and turning the command dial. The Quick-response mode snaps a picture when you press the button on the remote. The Delayed-remote mode gives you a chance to hide the remote behind your back.
Aug 01, 2008 | Nikon Cameras
Nikon Speedlight SB-800 TTL Flash Logo
496 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
