Question about Epson Stylus RX580 InkJet Photo Printer
Epson rx580 printer
New printer, new ink cartridges. Although I have carefully installed the cartridges 3 or 4 times, I keep getting the message. "Cannot recognize ink cartridges"?
  • 32 more comments
  • walter Johnson Aug 06, 2007
    I read your reply and said to myself I already did that, but I went back and checked again. I had already reinstalled the software. When I went to reinstall the cartridges, I noticed a little blue on another cartridge. I took a qtip and cleaned the electrical pads on each cartridge and on the printer. I replaced the light cyan one. When I hit OK to charge the cartridges, the printer went through a completly different charge sequence which worked. My guess is that the light cyan cartridge was bad. Thank you for your comment. The bottom line is, if it can't read the cartridge, it can't move on to anything esle, like printing. Thanks again.
  • moonjules Nov 16, 2007
    I have replaced all of the ink cartridges twice & cleaned the cartridege and connectors with a qtip & reinstalled the program now what?
  • Astrobot Nov 29, 2007
    I tried to use a "compatible" set of ink cartirdges for the Epson RX580, and the printer says "Cannot recognize ink cartridges". I bought a second set from another vendor; same thing.
    It says online that Epson RX580's bought after a certain date won't recognize any cartidges except Epson's own ink cartirdges. If this is true, I'll be spending $62 or more each time to replace the whole set!
    This is discouraging, and I never would have bought Epson had I known that.
    Have you heard of this?
  • hoogs Dec 10, 2007
    I have been using the same print cartridges that cam with the box for a couple months. Suddenly, there was a message that the printer cannot recognize the ink cartridges. I turned it off, and turned it back on, and it still said it. I took them out, and snappeed them all back in securely, nothing. I don't really know what to do next.
  • Anonymous Dec 26, 2007
    All of a sudden this is happening to me too. Sounds like a consistant problem with these machines. Nice Job Epson!
  • Anonymous Jan 01, 2008
    I have the same problem. I just set up my Epson rx610 and its telling me it can't recoginise the ink cartridges, yet I am using the ones that came in the box!
  • misterjad Jan 06, 2008
    same problem with the included ink cartridges of the rx585 ..... sigh
  • sarilyna Jan 07, 2008
    I had the same problem in August when I bought the machine. They sent me new ink cartridges, which worked. In November when I needed to change the ink cartridges, I had the same problem. "can not recognize ink cartridges". I called them again. They didn't offer any advice, but they shipped me a new unit, with directions on sending the other back. It worked fine for a month and a half. Now that I am replacing the ink, I have got the message again on the new one that Epson sent replace the other one. I'm glad I decided to look this up on the Internet because I figured if it had happened to me on two different units then it must be a common problem. I'm going to wipe the electrical contacts with a qtip. Hope it works. This is a great big pain.
  • Brenda Webb Eastman Jan 13, 2008
    I have the same problem with the printer not recognizing the ink cartridge. I cleaned off the electrodes still not working coul it be a bad ink cartridge?
  • Anonymous Feb 12, 2008
    Same issue - new printer, new epson ink - but the printer keeps displaying 'cannot recognize ink cartridges.'
  • Anonymous Mar 07, 2008
    I have the exact same problem, and it is a pain. SOmeone please give me an answer. Maybe all of us should get our money back.
  • aspecht Mar 10, 2008
    same problem here!
    I called tech support... They say
    1. take out the cartidges and replace.
    2. pull the power cord and wait 5 seconds
    3. if this doesnt work, buy a new printer from our "loyalty" websit
    I asked him, "So I can go to the loyalty website and buy a new printer that will break in one year,"
    "Yes," he answered
    I asked him if i could get my money back on the 100 dollar cartidges, he said no.
    I hung up
  • walter Johnson Mar 12, 2008
    I've had the same ink problem, which seems to come and go. Although this printer is selected as my default, every morning when I turn my computer on, and try to print, Have to delete the job, go to preferences, go to printers, reload the drivers, then print again. Then it works all day, but the first time I turn the computer off, I start all over????
  • drandy Apr 24, 2008
    fckin rx580 whenever the light cyan runs low. the printer fails to recognize any new ink cartidge. amy solution... maybe a master reset button sequence... damm i should have bought hp!
  • blmbob May 15, 2008
    Instead of saying one or two cartridges needed replacing, it said replace all cartridges. thought that very odd, but replaced them all with brand new Epson brand cartridges - $90 worth and then I get "can't recognize ink cartridges" error. I tried shutting off, unplugging, verifying they were "snapped in", verified the yellow tape was removed and cleaned contacts - both on the printer and new cartridges, but no go.
  • charlotte naone May 20, 2008
    i have full cartridges that i can't use because the printer says either replace in cartridge or can't recognize ink cartridges
  • greeenbr Jul 18, 2008
    My printer is saying I have to change the colour cartridges. I only use the grayscale when printing. I always print in black and white and my ink should not be running out. If the coloured ink is out... which it should not be!!!! why wont it let me print in black and white. I took each cartridge  out and put them back in and unplugged it. It still says replace ink 5 colour ink cartridges and not the black and I only want to use the black. Help!
  • sthielman1 Aug 03, 2008
    I had the message "Cannot recognize ink cartridges" and replaced them all with high capacity epson cartidges, and still have the same issue. Spent $100 on ink and can't use them. Will try cleaning with qtips.
  • Anonymous Oct 23, 2008
    WTF? What a waste of $
  • sdwyer0428 Dec 10, 2008
    I have the same problem. But when i insert one cartridge in, close it up, and hit ok, it goes thru the cycle, and recognizes the one cartridge, and not the others, i continued to add one more cartridge at a time, each time the printer recognized the cartridges and only told me the ones i haven't loaded yet. When i have one left, i put the last one in, hit the ok, and then all of a sudden the printer didn't recognize any of them again. I tried it again for a different color on the last cartridge, and same thing, didn't recognize all of them. Tech help is garbage also, routed me to the philipines and they have no clue how to fix anything. Please help, the printer is just over a year old, so warranty is up!
  • ataro Dec 20, 2008
    My RX 580 says it cannot recognize ink cartridges. Called Epson and they said I could send it in for a repair.
  • nicholas1987 Mar 24, 2009
    do not buy an Rx series printer they are a waste of money the ink runs really quickly. this all in one is a money pit. i have this problem where it cannot recognize ink cartridges. if i leave one out it will recognize that there is one missing and when i put it back in it says all the cartridges cannot recognize. i just got off the phone with there tech team they dont know anything about the printer its a waste of time and let me add this printer is maybe 7months old and they dont have any info about the printer. i will never buy anything off this company again. buy an HP you will not regret it believe me i have a small business and i go throw printers like water and i buy the warrenty that saves me from buying another printer but if you want headaches buy an epson..
  • Anonymous Apr 16, 2009
    I have the same problem with the epson cx8400 -- & had an experience almost identical to the one aspecht described on 3.10.2008. My questions is this: why hasn't epson been forced to issue a recall?
  • art_tech_uk Apr 22, 2009
    Epson are just a greedy company that don't like ppl to buy ink from anyone else and is the reason i believe they put that **** chip on just to make it hard for any cartridges to work other than epson origanals and the fact that ppl are also getting problems even when using origanals just shows how hard epson are trying to stop us using 3rd party cartradges. Ive had it with epson and because of there greed ill be getting a HP as my next printer.
  • Anonymous May 20, 2009
    Same problem here. Brand new cartridges, printer in less than a year old, and it "cannot recognize ink cartridges." Nothing precipitated it, either... it was working fine, then ran out of light magenta ink, and at some point before I could replace it the control panel lit up with the error message. From what I'm reading here nobody, least of all Epson, is going to be able to help. I've had great luck with higher end Epson printers, but maybe this consumer-grade garbage, like most consumer-level garbage, is to be avoided. You get what you pay for... I spent a little disposable income and got a little disposable printer.
  • Anonymous Mar 12, 2014
  • Anonymous Mar 23, 2014
    the two lots of ink were all bought at the same time, so they should work the same.
  • Anonymous Mar 25, 2014
    not recognizing new ink cartridge
  • Anonymous Mar 27, 2014
    my printer won't recognize one of the ink cartridges'
    added new ink cartridge and now it wont recognize it
    will not recognize new ink catridge
  • Anonymous Mar 31, 2014
    new ink cartridges installed but keep getting message to replace cartridges
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
Posted on Mar 12, 2008
  • sarilyna Jun 13, 2008
    As long as I can return the ink that doesn't work to office depot than I'm somewhat satisfied. about 1 in 10 cartridges doesn't work for me sometimes and I just return it. Epson returned my ink and sent me another printer at the beginning of the problem, before I realized it was faulty ink . I woul dlike to buy and HP also.
finally got mine to work maybe after a hundred (seriously) take in and take out of the same cartridge. The black would not recognize and I keep taking it in and out and then I remembered a trick I would use on other devices. I got a q tip and drenched it in alcohol, I used perfume because I was out of the stuff. Then I keep rubbing the metal part of the cartridge. I found that the more I rubbed it I found the q tip become yellow. My guess that since the yellow cartridge is next to the black, the color kinda got on the black metal part. I keep rubbing till the q tip became clean, waited until it dried, and then made a little prayer, then it worked!!!!!
Thank God because I was about to give up. I have a rx595 and I am using cartridges that are generic and the kind you can fill yourself. I would never pay the epson price on the ink, way too much.
Posted on Dec 26, 2008
I have had the same problem for a while now also. Just purchased all new cartridges, thinking it was them but same issue. When it comes up, and complains about a specific color, I just remove all cartridges and push them back in. It seems that the cartridges identified by the printer aren't always the cause.
Very annoying.
I am have thsame problem with lc mi final solution it's put a piece of totpick in te oposite end of te contacts maybe te contacts is misaligned
Posted on Jun 24, 2009
I threw the 580 away after over a year of being annoyed. I actually gave it to my ex-wife, who says it works perfectly?
Posted on Sep 23, 2008
Hey All,
Got a solution of sorts,
It works with an Espon RX-585 (UK model).
When an ink cartridge goes empty, replace all the original cartridges that came with the printer.
Then, remove one original and replace it with the compatible (knock off), Press the OK buttons and let the printer check it. Do this for all the cartridges, one at a time.
I know it is time consuming, but for me at least, it worked.
Hope it helps. Happy printing!
Posted on Aug 03, 2008
Thanks for everyones help, it appears I am not alone. I have never completely solved this error message problem, but I get get better and better at work arounds, and other tricks. This printer is not my most expensive piece of hardware, but I will never forgive epson for its performance. and Apple who recomended it. Henners
Posted on Jun 12, 2008
  • Bee-Rad Oct 30, 2010
    I bought the RX-580 because I knew I could buy a continuous ink system for it, which I did. I have NEVER bought another set of Epson ink cartridges for it. Found the printer on sale for $99 and paid about $80 for the ink system. I've used it for close to 3 years and only refilled the ink reservoirs once. I too had the "Cannot recognize ink cartridges" problem, but I just kept re-inserting them and it finally worked okay. (Probably bad electrical contacts to those chips that others described above.) Brad K.
    My current problem is that some nozzles remain clogged even after many cleanings. I've been trying to get hem cleared but have not been successful so far.
I posted this problem originally. After repeatedly getting this message,"can't recognize", I bought knock off catridges, and they have worked fine ever since, but....since I've used the knock off ones the printer won't work when I turn it on in the morning. I have to delete the first print job, go to preferences, printers, reload the rx580 drivers, and print again. After this it works perfectly all day, but I have to follow the same proceedure every morning. If I use the Epson cartridges I don't have to do all this reloading, but it works for a while then says, "can't recognize"??????
I'm currently running the knock off epson ink in the RX580 and just needed to replace the black. This time all I could find was the real Epson cartridges so I swapped it out with the knock off and got the "Cannot recognize ink cartridges". After fooling with it for a minute, making sure the contact was good, seated properly, etc... I popped all the cartridges out and put them back in and bingo, ink cartridges charging. For what it's worth; that is what fixed it for me, good luck!
Cut off the printer. open the access door under the scanner bed. ( the same door used to access the ink.) cut the printer on. when the ink tray moves all the way to the far left. use something like a rolled up magazine to obstruct its return to the right side. after you do that, the tray should move freely. (you should be able to reposition it where ever you like.) put the tray where you can access the ink. open the ink tray and remove all of the ink close the ink bed and turn on the printer. it will tell you to install the ink. (you may have to replace some if not all of the ink.) i'd like to end this little problem solver by saying F*@k you Epson. (p.s. dont bother calling the technical center if you own a mac. They discontinued servicing us.)
  • 161 Answers
Double check to see if the cartridges that came with your machine are really the correct ones. And if they are then make sure they are snapped in securely as they must make a solid contact to read the cartidges. Also make sure the drivers and software are properly installed onto your computer.Also make sure that the tape that is usually on the cartridges to protect them in handling and shipping are removed before installation.
Posted on Aug 06, 2007
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
My new pixma canon ip 2770 cannot recognize the black and colored ink
May 08, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Mar 28, 2010 | Office Equipment & Supplies
Same problem - printer will not recognize new ink cartridge...
Take out all the inks and power up, re install one at a time slowly and should be OK, if not, one of the sensors is bad and will need a shop repair. Make sure you can see ink in each of the clear plastic windows when held level.
Sep 10, 2009 | Brother MFC 240C All-In-One InkJet Printer
Canon iP4300 I normally refill my ink cartridges without any problems using ink from a Jettec kit. Suddenly the printer has said that I should replace one or more cartridges although they are all full....
You can only fill ink cartridges up to a maximum of 3 times, thereafter the chip on he cartridge need to be replaced. That's why u are getting that message my advice order a new cartridge.
Jun 10, 2008 | Office Equipment & Supplies
Epson Stylus RX580 InkJet Photo Printer Logo
16,682 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
