Question about Bosch SHU9915UC Dishwasher
Shu9915uc dishwasher wont drain
Can you tell me how to get my dishwasher to drain please. it seems to have water left in the bottom after cycle completes. thanks
  • 2 more comments
  • JoeDdg Feb 13, 2008
    Our dishwasher seems to cycle, but when it is through, the bottom is still full of water.  I tried pulling the water through the discharge hose by disconnecting it from the disposal and using a shop vac.  There did not seem to be any problem.  I hear the pump run, but no water is moved into the disposal.  Do I have a pump problem??  Is it difficult to replace the pump?
  • Anonymous Mar 15, 2014
    suds are left in the dishwasher after the dishwashing cycle has completed.
  • Anonymous Mar 18, 2014
    we have hard water, we don't use it often and we just changed powder detergent.
  • Anonymous Mar 31, 2014
    when i out the dishwasher on when its finished the water is still left sitting in the end of it
  • 183 Answers
It should have water just below filter tray, if it does not actually empty then you have a blockage ,remove left side panel to gain access to drain pipe and side chamber. Regards Engineer
Posted on Aug 05, 2007
I have to constantly do a manual drain which seems
i have the same problem....i would think the inlet valve is leaking....that would be the mechanism where the water supply is attached to the dishwasher.......did you get yours fixed? can you help please?
Oct 10, 2013 | Bosch SHU9915UC Dishwasher
Will not drain in drain cycle
If you can hear the pump attempting to pump the water out, disconnect the dishwasher drain hose and place a bucket underneath it and run the drain cycle again. This should clear any clogs along the drain line and prove that your pump works. While you've got it disconnected, remove the air gap vent and clean it. A small, but large enough amout of debris can be blocking the flow of water from the dishwasher's drain hose to the garbage disposal or drain pipe. The air vent has a small cap at the top that can be removed to make cleaning easier by simply flushing it with water.
Mar 20, 2010 | Bosch SHU9915UC Dishwasher
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Jul 31, 2009 | Bosch SHU9915UC Dishwasher
Clogged dishwasher drain?
clean the filter, check the water inlet and outlets for blockages
Jun 29, 2009 | Bosch SHU9915UC Dishwasher
Specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Mar 03, 2009 | Bosch SHU9915UC Dishwasher
Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Mar 10, 2008 | Bosch SHU9915UC Dishwasher
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Bosch SHU9915UC Dishwasher - wash cycle won't happen
hi there your dishwasher has gone into flood protection mode ie. water has leaked into the base and activated the float switch.
to try and locate the leak tip your d/w back to drain the water from the base then remove both side panels and start a program to see if you can see where the water is leaking from, being careful not to touch anything while the d/w is running as live parts are exposed
hope this is of some help
Dec 15, 2007 | Bosch SHU9915UC Dishwasher
Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Feb 05, 2007 | Bosch SHU9915UC Dishwasher
Pump Runs On After Water Is All Drained Out?
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Aug 12, 2006 | Bosch SHU9915UC Dishwasher
Bosch SHU9915UC Dishwasher Logo
428 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
