Question about Dell Latitude D800 Notebook
Touchpad of ibook locked
I have tried to install a program for my iphone, iousbfamily, after that touch pad is locked. Can u please help me?
Touch pad not working
It's a driver related issue or the touchpad is locked. Unlock it.
Each computer has it's own way on how to unlock the touchpad. Please provide me with the model of your computer so that I can provide you with the correct steps.
You can also scan your computer with RadarSync so that you will know if the drivers are out-of-date especially the touchpad driver. Your touchpad stops working if the driver is out-of-date so you might want to check RadarSync.
David
Jun 16, 2013 | BenQ Computers & Internet
First at all, I'm sorry about my terrible Eng. I have a HP 6720s laptop and there is a problem with touchpad. How can I disable the touchpad with 'fn' key? I looked every pages on my...
OK to disable you Touchpad you can press Fn + F12 or you can go to Control panel...Search for devices...or you can go to Device Manager. In the menu Look for sp/1 or sp/2 it will have your installed components or drive information for you mouse pad/touch pad. You can right click it and disable it. Also if you are having problems with you Touch Pad you can also download the driver and re-install in on your drive.
Go to this website: CLick Here For Hp Synaptics Drivers.
Click Your OS,
Search For Synaptics driver.
May 24, 2011 | Computers & Internet
Disable touchpad
hello... try to see if the touch pad application is correctly install,, to be sure use your application installer and try to reinstall your touchpad...
Mar 30, 2011 | Dell Inspiron 1300 Notebook
My toshipa satelitte pro touchpad doesnt work
check touch pad lock or install the touch pad diver of you machine again that u can get from support download option of toshiba website
best of luck
Jul 01, 2010 | Acer Aspire 5610-4648 Notebook
Touchpad not working
Touchpads have a cursor lock that suspend the use of the touch pad but allow you to use a mouse. Ensure that the cursor lock is not on. That lock is a thin strip just about the touch pad. Usually, it will light up when it's turned on. If you have that lock in the off position then I would not recommed that you go probing inside your laptop to relsove this issue. You should take your laptop to a qualified tech for repair.
You might have accidently turned off the touchpad software or driver. Use the RESTORE section of SYSTEM TOOLS in the ACCESSORIES folder of your Program Files.
Good Luck, and Happy Computing.
This link might help you in case of emergencies : http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Apr 17, 2010 | Acer Aspire One PC Notebook
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
Jul 30, 2009 | Compaq Presario CQ60-204NR Notebook
Go to device manager
Right click the touchpad device
Uninstall driver
Reboot system
go here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-66690-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795289
Reinstall touchpad driver
see if that helps
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Jul 01, 2009 | HP Pavilion dv4000 Notebook
I cant use my scroll down useing my touch pad
Please install the Drivers for the touchpad ,for Vista Operating system.
Mar 27, 2009 | Toshiba Satellite Pro L300 Notebook
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
IPhone touchpad only partially responding
I followed the following fix and it works. all rows are working based on this recommendation. I can not go to apple as I have used ziphone to unlock the iphone.
http://limitededitioniphone.com/iphone-touchscreen-fix-increase-sensitivity/
Jan 06, 2008 | Apple iPhone Smartphone
Dell Latitude D800 Notebook Logo
70 people viewed this question
Alun Cox
