Question about Oki Printing Solutions C9650 Led Printer
Oki c9650 error 360
360
Error sensor
Toner is a Black in cartridge that needs to be replaced once it runs out.
Nov 06, 2013 | Oki Printing Solutions C9650 Led Printer
How do you fix density shutter error and sensor calibration error on OKI C9650 Printer
The shutter protects the density sensors and keeps the windows on the sensors clean, until they wear out. Replace the shutter assy (part number 42755401) and clean the sensor windows.
If this doesn't solve the problem, you may be at the beginning stages of a broken gear for the top cover mechanism that protects the LED printheads when the cover is open. As a test, you can remove the 4 black protective covers from the printheads and see if your machine will calibrate itself. If it does, I recommend leaving the protectors off and just be extra careful of the LED printheads when you change toners...
Jul 06, 2013 | Oki Printing Solutions C9650 Led Printer
Density shutter error
The density sensors are dirty (probably toner on them). This is usually caused by the cleaning blades being worn out on Item #31 on Printer Unit page 2/2 part number 42755401 needs replaced.
Printer Parts Diagram and part numbers
Jul 05, 2013 | Oki Printing Solutions C9650 Led Printer
Oki c9650
The top cover mechanism that protects your LED heads has broken gears that operate the protection shields. As a test, you can remove the 4 black shields from the LED printheads and see if the printer now prints correctly. If that fixes it, then I recommend leaving the machine that way as replacing the entire top cover is the solution...very expensive if it is still available to purchase.
May 01, 2013 | Oki Printing Solutions C9650 Led Printer
Fatal error 142
Color ID up/down error
is detected.
1) Is an Error message displayed?
Confirm that the Y, M, and C ID
units are in position, and reboot
Mar 04, 2013 | Oki Printing Solutions C9650 Led Printer
Oki C9650 not printing Yellow
remove the unit
open the cleaning lamp cover (front of unit)
turn O.P.C drum gear and check that toner is always applied to the developer roller
Sep 27, 2012 | Oki Printing Solutions C9650 Led Printer
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Oki c9650 paper jam
I would recommend removing all paper trays and opening any hatches that are not screwed down. With this done please check the machine thoroughly and hopefully you will spot the paper in question.
Please bear in mind that even small scraps of paper stuck in the printer can cause this error if they are covering a key sensor.
Once you are confident the offending paper has been removed just closing all doors and replacing the paper trays should make your printer check for paper again (although some models will require you to indicate the jam has been removed).
My oki c9650 say service call 256: Fatal error
jcampos,,, pudistes solucionar este problema del error 256... tengo el mismo..
Feb 02, 2011 | Office Equipment & Supplies
Oki Printing Solutions C9650 Led Printer Logo
37 people viewed this question
Top Oki Printing Solutions Office Equipment & Supplies Experts
Roger Binsfeld
richie46
Ron Baird
Are you an Oki Printing Solutions Office Equipment and Supply Expert? Answer questions, earn points and help others
