Question about GPX ML648B MP3 Player
Player does not charge from USB port
The player shows Z's and the battery does nort charge.
  • damonx3 May 11, 2010
    howdo you charge it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 96 Answers
Make sure no other devices are plugged into your computer at the time. Also try restarting the computer with the device still connected.
If operating on a laptop be aware that you may not be receiving enough voltage to your USB port to satisfy the MP3 player. Try disegaging the laptop batter for an hour and then reconnecting it.
Posted on Jun 05, 2010
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
I dont how charge battery on my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Audio Players & Recorders
How dont know how to charge my mp3 player
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My fuse wont charge at all. i bought a new charger and still get no charge
USB Port 2.0
USB Port location
Battery
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
It was kept idle for 4 months.when power button is pressd the screen shows "battery is too low system shut down".when charging is tried through PC USB port there is no proper charging
Not all computer USB ports put out enough current to charge batteries. If you have another USB port on your computer, try that. Try another computer. If that doesn't work, try an AC-to-USB charger, as you might find for cell phones.
Nov 17, 2010 | SanDisk Sansa e260 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
GPX ML648B  MP3 Player Logo
95 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
