Question about HP Photosmart C5180 All-In-One InkJet Printer
Black ink leaks out the far side.
Doesn't leak under the black but the end with the Magenta, which leads me to believe it is the Magenta as I seem to replace that cartridge the most often.
    President:
  • 2,692 Answers
Take them out and see which is leaking. I believe you wil be able to tell.Then replace it.
Posted on Mar 12, 2009
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
EPSON STYLUS PRO 7600 Leaking ink One of my
sir the printer head of your printer is already thin... try to change the printer head...
Oct 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
Clogged print heads
Sure, you can do it. And it will happen again for long time using. Usually, it happened if using non dyes ink, like pigment ink.
Jan 21, 2013 | Epson Stylus Photo R800 InkJet Printer
My 99 cavalier 2.2 is leaking water / coolant on the left hand side of the engine area. It leaks while driving and while the car is not running. As far as i can tell its not leaking into the oil and not...
no freeze plugs are located on the sides of that engine... the front and back when viewed under hood.... i believe your resivoir- overflow is on the same side as you describe the leak so id check that first otherwise it seems youve a thermostat housing, intake manifold leak or another waterpump issue
Oct 13, 2012 | Cars & Trucks
Purging air from ink tubes z2100
While printing,air pump pushing pressured air in to the cartridge bank to force ink out through ink tubes tubes..During this process any leak at the cartridge neck or blockage in cartridge needle causes leak. Remove all cartridges check two needles inside the ISS unit for each.. upper needle allows the ink flow in to the pipes and below needle pumping the air inside the cartridge bank..If any blockage in upper needle causes ink leak. My sincere advise to the users better replace ISS unit & stop printing for further damages..For Tech guys only: Remove ink supply station along with ink tubes out,gently detach both tubes(magenta), you can see the needle other end pump syringe alcohol with the help of syringe, do this process up to free flow.. once confirmed refix tubes back, ensure that no leak should not happen.. fix all back.. try...This advise purely professionals can perform.. others strongly cautioned.
Jan 31, 2012 | HP Designjet 4000ps InkJet Printer
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Error message is telling us we are out of ink we just replaced
This problem needs to be addressed by an Epson service center. It needs disassembled and probably needs parts replaced that the leaking ink damaged. Sorry.
Dec 28, 2008 | Epson Stylus Photo RX500 Printer
Canon Pixma 4500 when printing on photo paper there is a Magenta cast over the print, even on black and white prints
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Nov 12, 2008 | Canon Office Equipment & Supplies
Brother MFC-215C leaking ink
Buy a new printer ....unless it is a dodgy refilled magenta ink that is leaking,  if you are indeed using genuine Brother Inks then it will need a purge unit which is too costly to repair
Oct 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
