Question about Craftsman Garden
Shaking and vibrating
Had the mower serviced and there were no bent blades or shaft. Any other suggestions?
  • Craftsman Master
  • 7,482 Answers
You have a bent shaft...time to replace the motor
Posted on Apr 25, 2013
  • 48 Answers
SOURCE: Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Posted on Oct 17, 2008
  • 279 Answers
SOURCE: Locked up Eager 1 6.75 Craftsman Mower
The timing may be off due to a bent or broken flywheel key. See if you can remove the flywheel and look at the keyway. To remove the flywheel: take a nut with the same size threads as the one that holds the flywheel on. Thread it on but not so far as to let the shaft come through. With your weak hand, lift the flywheel with a little upward pressure. With the strong hand, tap the nut with a wooden mallot if you have one. If you dont, use a hammer. Tap the nut and the flywheel will come off. You may have to tap it sharply. Once you have done that, remove the nut and save it for another day. You will be able to see if that is the problem. Good luck...Lee
Posted on Sep 03, 2009
  • 110 Answers
SOURCE: Bent Shaft???
Check that the blade securing bolt is secure. While you're there, have somone SLOWLY pull the starter rope. It will be obvious if anything is bent to the extent you describe.
If this machine has a blade clutch, engage blades while you do the pull test (DISCONNECT PLUG WIRE!!!!)
Posted on May 09, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
Posted on May 26, 2010
Testimonial: "Your response was very helpful. Is there a repair manual or instructions online that I could get to describe the process to repair the mower? Again thanks for your response. "
hunter19_46m
  • 7482 Answers
SOURCE: My wife hit a stump
Hi ptcbob7...
Yes, she bent the crankshaft...very hard to get the bend out, most of the time a new engine is in line.
Being that your going to have to replace the motor anyway...I would take a large hammer and give it a good whack in the opposite direction of the bend, it may not take it all out, but it will take out some of the bend.
Please take time to rate me
Posted on Aug 30, 2011
What caused a vibration in the handle of my push mower?
a bent crank shaft or a damaged blade. have the blade balanced. should be good. unless you have hit something and damaged the crankshaft.
Apr 21, 2016 | Garden
Why is my electric Black and Decker lawn mower still vibrating and loud after I replaced the blade insulator and fan?
disconnect all power and turn the mower on the side
turn the cutter blade /base by hand and watch the centre bolt or shaft
if it moves in a bit of a circle then it indicates that the motor shaft may be bent, causing the vibration at speed
Aug 03, 2015 | Electric Garden
Hi my lawn mower shakes so much it feels as if the enging is going to fly off.i did call a repair guy he said it sounded like a coil? is it posable for me to fix it? craftsman briggs & stratton 4.5...
Did you hit something with it? The blade might be bent, so try replaceing it. If the shaft is bent, the mower is junk, but if its just the blade being bent, its a cheap fix! The motor is NOT the cause of the shaking... Trust me on that one!
Sep 24, 2011 | Briggs & Stratton Garden
Craftsman 19.5hp 42'' deck lawn tractor with vibration only when the cutting blades are engaged.I have changed the blades but the the tractor still vibrates alittle. when I disengage the blades the...
Check your spindles, especially the shafts in the spindles. If one of them is bent, it'll make the blades vibrate as they spin. You can find replacement shafts and spindles at Partsbuggy.com.
Dec 18, 2010 | Garden
My 18" 12 amp B&D mower has become loud and vibrates so much that the wheel height adjustment pops out. Any suggestions?
Most likely bent shaft or blade. Worst case motor is on the way out maybe bad bearing or something along those lines.
Sep 18, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Hope this helped,
Please rate me
May 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Bent Shaft???
May 09, 2010 | Mtd 22" Yard Machine Push Mower
The mower vibrates hard I replaced the fan and
you could have a bend blade or bent armeture shaft if you hit something that hard
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Motor vibrates the entire mower, new motor pulley; belt and deck pulley replaced by serviceman. Continues to vibrate. Craftsman YTS 3000
Doesa the vibration happen when the cutting blades are engaged or do you still have vibration when blades are not turning? IF BLADES ARE TURNING AND YOU HAVE VIBRATION, YOU NEED NEW BLADES OR THEY GOT BENT FROM HITTING SOMETHING HARD AND NEED TO BE STRAIGHTENED OR REPLACED. If vibe is there when blades are still, possibly the output (crankshaft) is bent. Goodluck, Macgivor
Oct 24, 2009 | Garden
Rotary cutter shakes
If a roc bent the pan - I dont see how that would make it shake..
I suspect the shaft..
Hoe this helps !!
Jul 14, 2009 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
