Question about John Deere Garden
Sputter power Have an x530 mower that sputters after it has run for about 10 mins or so, mostly when the mower deck is engaged. Seems to be a fuel issue but have changed filter
SOURCE: spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
shadtremonky
  • 353 Answers
SOURCE: engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: Mower has to be chocked to run
It still sounds as though there is a passage plugged in the carb or maybe a leaking gasket. The carb is obviously not pulling gas through as designed, which explains the need for choke. Try a rebuild kit, and blow carb cleaner through every tiny passage.
Posted on Jun 25, 2009
  • 202 Answers
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Posted on Jul 07, 2009
  • 61 Answers
SOURCE: engine runs but sputters after engaging blades
ck for water in carb bowl. also ck for filter in gas tank, or something in gas tank.
Posted on Sep 06, 2009
Mower starts out with a full gas filter for about 25 min. then starts to sputter and barely has a trace of gas in the filter.
It doesn't have to have a full filter to run, but the sputtering and fuel line volume indicates fuel starvation or a type of vapor lock (from a vacuum situation). A mower like this has to vent the fuel tank or it will only draw a while and then no more. Your gas cap's threads are the actual vent for the tractor. Try running it with the cap on somewhat loose, Post back if needed.
Sep 13, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
Mower sputtering and getting hot
To help stop the sputtering you will need to tune up your mower. As for it getting hot check the air filter, and the top air draw area to ensure that they are clean. During your tune up be sure to replace the oil, spark plug, and fuel filter. If your air filter is dirty replace it too.
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Spitting and sputtering
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine coughs and stops after about 15 min. of cutting
Apr 25, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
