Question about Stanton CMP.800 CD Players
How do I download mp3 or I tunes to a cd stanton cmp 800
Downloading I tunes to cd stanton
Stanton c324 will not play disc after replacing laser
Have you removed the blob of solder on the laser board thats left there to protect it from static while handling it
Jun 07, 2014 | Stanton C324 Mp3 Cd Player With Effects...
Stanton c304 cd to mp3
Sorry you cant convert it to MP3 the deck only supports CD audio
Feb 04, 2013 | Stanton C.304
Stanton c.324 wont eject cd's
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is displayed here in web.
You can get details to this fault from here.
May 15, 2012 | Stanton C324 Mp3 Cd Player With Effects...
I have the stanton c324, every time i put the cd in, it want to read it. then it said no disc. i told it apart and clean the len, and it still said no disc. is there a repair shop in southern California or...
If you took it apart you might of voided the warranty. Try buying like a cd cleaner they sell them at bust buy and stuff and give that a try. If that doesn't work. Contact Stanton and Have them take a look at it for you.
May 05, 2011 | Stanton C324 Mp3 Cd Player With Effects...
I have a Stanton C.324 CD player. When I load a CD in the unit it reads "No Disc". What is the cause of this error?
It could be caused by a few things :
1) The CD was not burned correctly or did not complete. Try using an original CD and see if it works 2) Some MP3s when downloaded from online sources have a digital protection which prevents it from playing once burned into a CD. 3) The brand of CDRs you are using are not good. Try another brand
If all the above do not fix it, I recommend that you send the unit for warranty or repair. The optical laser could have been damaged.
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
My stanton reads no disk
If your device is old? it might have a busted motor inside, get technician to do it for you,
Feb 04, 2011 | Stanton C324 Mp3 Cd Player With Effects...
Connot find files after downloading mp3 to nano
you must download through i tune software.
Download install I tune Software. then send start downloading through i tune
Jun 27, 2009 | Apple iPod nano
My i-pod nano (2GB) will not hold more than 43 songs when I import from my cd's. My ipod is clear of all songs and so is my library. Are I not suppose to have at least a 500 song capacity?
I have an I-pod nano 4 gb. What I think is going on is you are loading full "wav" files. The 500 songs is predicated on low quality "mp3" songs. Normally, I-tunes will convert the "wav" file to an "mp3" file.
Check your music files on your computer and assure they are "mp3" files. If they are make sure your I-pod does not have other "stuff" on it. Use I-tunes to reset it an "like-new" condition (that removes all files)., then use I-tunes to re-install your music.
If you are downloading files from the I-tunes store make sure they are safe so you do not loose your investment in tunes.
Since they are from cd's make sure the ripped files are safe, then try a re-install.
Should work.
Cheers
Mar 30, 2009 | Apple iPod nano
Stanton C.314 CD tray wont open
You can replace the cd drive by ordering another one from American DJ online.Give them the model number and replace about three multiple connectors in the same order you have the bad one. That will fix your problem.
Jan 02, 2009 | Pioneer CDJ-800 Turntable
Stanton CMP.800 CD Players Logo
13 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
