Question about AOC Computers & Internet
Monitor stand stuck
The stand is leaning vertically rather than leaning slightly back...
2 Suggested Answers
SOURCE: Cannot raise vertical height after pushing button on back of monitor (button stuck in)
With the monitor in the lowest position, push down slightly on the monitor and push the button in. While holding the button in you should be able to raise the monitor with your other hand. This worked on the one I have.
Posted on Jun 04, 2010
When they are placed on speaker stands, they lean to one side since all the weight from the components are on one side. Is there a simple way to fix the leaning issue?
Remove one of your shoes. This will cause you to lean slightly and therefore not notice the slanting speakers. It will also improve the quality of your recordings, with deeper bass and a clearer soundstage due to quantum grounding effects.
Dec 29, 2015 | JBL PRX615M 15 Inch Two Way Self Powered...
How do you take the back of a Samsumg Syncmaster P2450 Monitor
there r plastic moulded locks..open with pryin with a knifed screw driver safely after unscrew all the screws
Apr 22, 2012 | Samsung SyncMaster P2450H 24" Wide TFT...
My dc14 wont stand vertically, it stands slightly leaning backwards?
There is usually a stopper that you step down on to bring it down, its stopper should be loose, or needs to be replaced.
Jan 30, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I just purchased a 52 inch phillips tv and the stand that the tv sits on adds 2 inches which doesn't allow the tv to fit in my entertainment center. What can I do?? I need a shorter stand...
Just take off the stand altogether if you can lay the TV close enough to a solid vertical support.
My 47'' Philips spent about a year without a stand sitting on a desk and leaning on a wall.
It's heavy enough and as you approach to completely vertical position its main force will be pointing down, not forward.
If you can't lean it on anything solid or if it doesn't sit well while in an entertainment center...not sure what I'd suggest....short of adjustable wall mount stands...
Nov 07, 2009 | Philips 52PFL3603D/27 52 in. LCD HDTV
May 01, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Pedestal fixes screen tipped forward. Is there any adjustment to fix screen tipped slightly back?
most screens are on a pivitable base stand.if it falls forward or back open or remove the cover from the base stand connected to the back of the monitor and tighten the nuts at the sides.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Jun 10, 2008 | AOC Computers & Internet
Position of monitor
There is no mechanism on the stand to raise or lower the monitor.
Aside from removing the stand an setting the monitor on the table leaning against something or machining a shorter stand, there is no way of lowering the e196fp display
May 31, 2008 | Dell E196FP 19" LCD Monitor
Small annoyance with HP P1100 monitor. Slightly darker vertical lines.
Sounds like dried out electrolytic caps. How old is the monitor ?
Dec 19, 2006 | HP P1100 21" CRT Monitor
Computers & Internet Logo
22 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
