Question about Garmin StreetPilot c550 GPS Receiver
Was working then randomly and then stopped altogether
The icon that is on the front of the screen was always lit not it is no longer thereand no longer anwering the calls. Tryed to follow prompts to enable it again but it is stuck on enabling screen I have to unplugg the unit to make it go back to the main screen.
  • neece_verdug Mar 12, 2009
    how do I remove the face plate
  • 6,784 Answers
You will need to reset the unit by pulling off the face plate. once you unplug and power off the unit, hold the reset button down for 5 secs. after you release the reset button, power back up the device and it will be normal.
Posted on Mar 12, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Mar 12, 2009
    place your thumbnail in the groove under the Garmine logo on the face plate and gently pull off.
  • Michael Masters
    please rate my response if possible, thanks.
  • Michael Masters
    be sure to keep the system software updated for optimal performance.
What would cause the speedometer to stop working?
try the connection on both ends may be loose or broken
Sep 29, 2017 | Buick Cars & Trucks
Why are these lights on in my 2008 xl7
These icons are yellow and as such do not generally mean there is immediate danger, but rather to alert you that service is needed when lit. There may be little or no change to the way the car drives or handles when these colored indicators are on (Check Engine, Service Engine Soon, etc.).
Red icons on the other hand indicate a serious condition that requires immediate attention when lit. This usually means stopping and shutting the engine off (Oil, Temperature, Brake, etc.).
The icon to the right of the Tachometer is the "Anti-lock Brake System" (ABS) indicator. This is not the normal state when lit. This means there is a problem with the antilock brakes but your regular brake system is working. You may experience longer stopping time in a "panic stop" due to locking up the brakes.
The Icon above the Odometer indicates the "Traction Control System" (TCS) or "Traction Assist" (TA) is *not* engaged. This is NOT the normal state. The TCS / TA is a secondary function of ABS, so it is not unusual to see these come on at the same time as a result of the same problem.
These systems are in cars made in the last 15 or so years and provide safer starts and stops via computer control of the application of the brakes. You should bring the vehicle to a trusted mechanic or dealer for proper diagnosis and an estimate for repairs. Until then, the vehicle *should* operate as normal, except in cases of slippery roads or emergency / panic stopping.
I hoipe this helps and good luck!
Mar 01, 2013 | Cars & Trucks
E6410 Bluetooth randomly shuts off
The mouse is the issue, check all connections and battery contacts, if unit can run on standard battery, " replace " to see if that will help, and make sure wfi plugged into laptop properly,also try another usb plug on your laptop.
Apr 02, 2012 | Dell Latitude E6410 Notebook PC Core i7...
Default 2003 chevy surburban I have an issue with my 4wd selector switch. Each time you start the vehicle it doesn't remember the last setting. It can be in 2 hi, 2 low, auto, 4 high, or 4 low. Seems...
I have the same problem. I have had it in the shop on numerous occasions and they couldn't find the problem. Yesterday it stopped working altogether. I'm stuck in 2WD and there is a snow storm arriving tonight.
Jul 20, 2010 | 2007 Chevrolet Tahoe
Micron Trek 2 laptop won't start on battery or AC (NBKU375)
The lightning bolt is used to indicate an electrical problem but then, you know that already :-( Try removing the battery pack and start it from AC only; some battery types don't like to be ignored, they can have individual shorted cells.
Sep 30, 2009 | Computers & Internet
Frozen mouse icon
press fn key along with f9 to enable and disable the mouse pad. some laptops use diffrent keys so it isn't always F9. usualy there is a mouse pad icon on the key.
Jul 28, 2009 | Toshiba Satellite M35X-S161 Notebook
Garmin StreetPilot c550 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
