Question about Car Audio & Video
Protection light wont go off
Hello i was listing to my music and then turned it down and 2 minutes later my protection light came on and now it wont go off. I had music down very low so there was no risk of blowing amp. Can you help?
  • Perry Babin May 11, 2010
    If it goes into protect with no speaker wires connected to the speaker terminals and no RCAs plugged in, it likely has shorted output transistors. Read through the following page if you want to try to repair it yourself. Let me know if you have any other questions.
    Basic Amp Repair Primer
    Problem Solver:
  • 7 Answers
Try checking the ground cable it migth be loose.. this happen to me once and it was a bad contact ground make sure the area is clean and tigth
Posted on Mar 13, 2009
Well i was driving one day and my subs just whent out so i bought brand new wires and hooked everything up but the power protector light turns red whenever uu turn it up past volume 10 i really do not know...
It sounds like your amp is going into protection. I know it's frustrating, but this is actually a good thing. If you subs you have are drawing too much power and the amp can't keep up, it will shut off instead of melting the board. Usually, the protection mode only last a few seconds. The user normally turns the music down that the protection shuts off and the music plays again. I recommend looking at a larger amp for your subs, if you are going to play them that hard.
Aug 14, 2011 | Car Audio & Video
It probably has a fault.But try this.Disconnect all speakers and inputs and try again.If that works reconnect the speakers A PAIR AT a Time.That should lead to the fault.If that still shuts down.
the set is going into protection mode. This is caused when ever one of the many sections of the tv has a shorted circuit. The increase in current is detected by the protection circuit and it flies into action by turning OFF the ON relay.
Most often, but not always, it is either the high voltage section or one of the deflection amplifiers. But can be the power supply, the audio amplifier or voltage regulators, etc.
Feb 19, 2008 | Samsung HLN5065W 50" Rear Projection...
How to Enjoy DRM Protected Music
To enjoy DRM Protected Music, you should remove DRM protection from the music files first. This article contains three parts:
Part 1: What's DRM
Part 2: Why need to remove DRM
Part 3: How to remove DRM from protected music
Part 1: What's DRM
DRM, Digital Rights Management, refers to a range of access control technologies that limit usage of digital media or devices.
Part 2: Why Need to Remove DRM
DRM protection has been used by some big companies to protect their intellectual property rights, such as Sony, Apple Inc., Microsoft and so on. Music bought from different companies will have different DRM protection that can restrict you from playing songs on incompatible players. So you just can't copy your DRM protected music or share DRM protected music with your friends. There comes the headache of removing DRM protection before you enjoy DRM Protected Music!
Part 3: How to Remove DRM from Protected Music
Following is the step by step guide to help you remove DRM protection then you can enjoy DRM protected music freely!
Step 1: Add files
Free download Aimersoft Music Converter and run it. Then click "Add" to load your DRM protected music files.
Step 2: Output settings
Click the "Setting" button to set the music output format as you like:
Step 3: Start to remove DRM from protected music
Click the “Start” button to start to remove DRM from protected music files, that's all.
OK! You have finished to remove DRM from protected music files and now you can enjoy DRM protected music freely!
Note: With this music converter, you can also convert M4P to MP3, M4P to WMA, WMA to MP3, AAC to MP3, etc.
more information: music converter media converter
Connected information : dvd to ipod touch dvd to iphone video
on Jun 03, 2010 | Computers & Internet
Red protection light wont turn 2 green no matter what so the amp wont work
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Aug 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes...
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
Oct 01, 2008 | Audio Players & Recorders
Protection mode overuse
Flashing protection LED indicates there is problem with circuit. Have unit serviced
May 10, 2008 | Cambridge Audio Azur 640A Amplifier
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
No power
your set needs a tech due to excessive voltage the regulator got very hot causing it to damage when opperating systems a fan is needed to cool it off.goodluck.
Mar 29, 2007 | Yamaha RX-V1500 Receiver
Cicuits Protection
You have a power supply circuit problem,you need a qualified serviceman near you.
Nov 27, 2006 | Technics SUV500 2-Channel Amplifier
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Car Audio & Video Logo
209 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
