I have canon image runner 2420 error code E000003-000
  • 47 Answers
SOURCE: Canon 210S Image Runner
It is a fixing film position error. The fixing film is probably damaged or is just tracking off center. If the fixing film is ratched then replace the entire upper fixing unit. You can get just the film but its a job even experienced techs cringe at. Check the lower roller and bushings while you are at it. If anything is worn there it can cause the film to track off center.
Posted on May 07, 2008
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Posted on Oct 15, 2008
SOURCE: Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Posted on May 20, 2009
57 varieties
  • 1653 Answers
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Posted on Oct 13, 2009
Canon Image Runner 2420 it has error code E000100-0000
Hi, that error indicates there is a problem with the laser unit, maybe is dirty or defective
Apr 18, 2018 | Canon Office Equipment & Supplies
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
How do i update my canon image runner 2420 firmware?
probl?me avec canon Image runner 2420, voila le message d'erreur :
update firmware
bios mode x
2010/10/28
waiting dating
Dec 17, 2014 | Canon Office Equipment & Supplies
How to resolve problem for canon imagerunner 2420L pritner error show "restart if problem persist "
There should be an error code on the screen too, what is it? it should start with E
Sep 06, 2014 | Cannon Office Equipment & Supplies
Update firmware to ir 2420
BIOS MODE wait updating F/W for canon ir 2420
May 26, 2014 | Canon ImageCLASS MF4370dn Laser All-in-One...
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Need help imageRUNNER 2422/2420 fail to run the scanning senser getting stuck giving error code E000007-000
MODEL NO. : IMAGE RUNNER 2422/2420
NO WORK SCAN. WHEN I PRESS "SCAN" BUTTON SHOW "THIS FUN. REQUIRES OPTIONAL EQUIPMENT" IN DISPLAY BOX. PLEASE HELP ME HOW TO SETTING AND SOLUTION THIS MACHINE. SO HOW TO SCAN FRO PC AND SETTING? THANK YOU
Sep 18, 2012 | Office Equipment & Supplies
What is remedy error code E000007-0000 for canon imageRUNNER 2422/2420
A E000007-0000 means that the fixing film is out of "HP" The fixing film has a white patch that is the home position and as the film is turned, there is a sensor that reads it in & out of "HP". Odds are that the film is ripped on one side and the film moved toward the front of the copier and the sensor can not read the patch. You will need to replace the upper film unit or the whole fuser unit to repair the problem.... Good Luck
214 people viewed this question
k24674
jasbo
jasbo
