Error code c-e002 bizhub c450 - Office Equipment & Supplies
Nitrotrike
  • 589 Answers
SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Posted on Feb 10, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
rcampsr
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
  • 16 Answers
SOURCE: a canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Posted on May 14, 2009
SOURCE: C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Error c3451 for bizhub c450
Error c3451: "Heating roller warm-up failure"
Oct 12, 2014 | Konica Minolta 120v Fusing Unit For Bizhub...
How i can rest error code c-d231 on bizhub c450
CD231 in Bizhub C450 come due to missing of DIMM memory board in Fax board.
in service mode(Utility-counter-Stop-00-Stop-01) -system2-option board-unset the Fax1 and fax2 and re-start machine .
Jul 03, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub Konica Minolta - Error Code E002
Sir/ma could not find that code for a Bizhub 200
Jan 15, 2014 | Minolta bizhub 200 All-In-One Printer
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Minolta C450 fault code C-2656
konica minolta bizhub c450 error code c2656
Feb 09, 2013 | Konica Minolta Office Equipment & Supplies
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
Bizhub C450 error (C-0212)
Feb 04, 2008 | Konica Minolta bizhub C450P Laser Printer
142 people viewed this question
jasbo
jasbo
