Question about Technics SA-DA10 Receiver
No, its my Technics SA-GX550 amplifier - have a problem - HELP!!
The overload light comes on so nothing works. This is with nothing hooked up to the thing. My email is rogervice1@sbcglobal.net i have the same problem whit SA-DA10 ( overload ) also if i turn up the volume or bass .If it works it works good. i bought it in this state . what about the light in the volume button and input selector ? mine doesn't work . i allready checked the connections some have already been repaired the rest looks good can't see anything bad . WHO CAN HELP ME this thing must show it's beautifull sound . Could it be a slightly defected condensator ? or defect in the Fan ? Greetings Jan Henk from Delfzijl Holland
  • 1 more comment
  • hennep Mar 13, 2009
    Ok then i have to take a look at it again . my fan doesn't work either who knows where the sensor of the fan is located ? the E Mail adress in my message isn't mine it came from someone whit the same problem.
  • hennep Mar 14, 2009
    yes that's the best i can do but i allready did that and he said its 1 faulty pre out channel but i think its the fan that doesn't work because it shut's down when it is getting hot . I have tested the fan it works good so it has to be the sensor of it because it doesn't get power .
    Ok i checked it again and find something. Next to the cooling ribs on the lower ( biggest ) print plate near the 2 black transistors ( there's a little plate over them whit one screw ) on the cooling ribs there's a Diode missing . Its number D 708 . Can someone tell me what cind of diode it needs to be ? Someone whit the same reciever maybe ?
  • 583 Answers
You probably need to check the whole board with multimeter as it looks that multiple parts having problem on it.check all the components on the main board and replace the faulty parts.or taking it to a technician is also very much adviseable
Posted on Mar 13, 2009
    Genius:
  • 1,269 Answers
The relay circuit might be grounded. You need to check potential burned components on the circuit board.
Posted on Mar 12, 2009
  • Technics Master
  • 19,396 Answers
You need to take apart the unit to test it , startig from the volume controls.
  • Ginko
    Ginko Mar 12, 2009
    You need to disassemble the unit and test the internal component to fix the problem.
    If the unit goes in overload only on low colume, then the problem can be a faulty volume control, replace it.
    To test the rest of the unit , grab a service manual and test components following the troubleshooting diagrams in service manual.
    You can get service manual from websites below:
    Technics SA-DA10 Service Manual
    Technics Service Manuals
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a technics sug91 amp the over load light comes on what can i do to remove it
you cant remove the overload light. it does that as a safty so you dont burn up the amp when its not being used properly. do u have a capacitor? are the speakers ohms and watts the same as the amp?
Oct 18, 2009 | Technics SA-AX540 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
Im having the same problem with mine. The problem seems to have started after I placed a vcr on top of the unit. I am thinking that It may be getting too hot. But don't really know.
May 05, 2008 | Technics SA-DX750 Receiver
Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Feb 23, 2008 | Technics SA-DA10 Receiver
Technics SA-DA10 Receiver Logo
376 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
