Question about Kenmore Kitchen Ranges
The control panel stoped working.
When i push any of the bottons to set the clock or the to turn the oven on nothing happens. the clock is on.
  • Kenmore Master
  • 3,361 Answers
Unplug the range for 30 seconds, then plug it back in.
If it does not work,
Replace the clock.
Posted on Mar 13, 2009
On my steering wheel there are 3 bottoms. Button one is a large botton with a clock wise looking option. What's this? Now there are 2 buttons on the right hand side of my steering wheel. One botton...
this is controls for your cruse control. The clock looking button turns it on. The + set is the button you press when you are at the speed you want to stay at. the same button and the - button are yo adjust the set speed +2 kph or -2 kph that goes in 2 kph increments. So for example if you press the set button and you decide you want to speed up 10 kph... press the + button 5 times... this will increase the speed by 10 kph. and of course the opposite happens when you press the - button.
Jan 06, 2015 | Ovens
1965 Moffat Electric Built-in oven - model #21K90. No manual and no information on any of the websites I've searched. There is power (oven light, warmer light, rotisserie, power rack), but clock and...
My father solved this one, those clocks were such a hassle, ours buzzed for days til he fixed it. It requires opening the control panel and bypassing the wiring that allows the clock to turn the oven on and off. Of course you lose this function. Is that the complete model number?
Oct 26, 2013 | Ovens
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
None of the bottons work, tried to cancel but off came on.
Ok, will it allow you to reset the clock? That has to be done before you can use the oven.
May 20, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Reset clock - how do I do it?
Push and hold clock botton, until display changes, then use the scroll controls to change numbers, then when the time it's correct, press clock again to enter settings
Dec 23, 2009 | Candy Ovens
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Kitchen Ranges Logo
89 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
