Question about Toshiba Gigabeat MEG-F20K (20 GB) MP3 Player
I cant seem to load music in to my gigabeat
As soon as I synchronize the music from a cd to the computer the computer exits the program and nothing is loaded.
SOURCE: Computer does not recognize Gigabeat Device
I came across this link, its a firmware / software update.
Install this and vista should recognize gigabeat.
Vista does not recognize ANYTHING, if you have XP then KEEP IT.
I have learned about vista's compatibility issues the hard way,
and now im stuck with Vista and lovely payments from Dell.
Posted on Nov 28, 2007
SOURCE: how do i load movies on my gigabeat
change os to rockbox. download from follow instructions on how to change the system to rockbox. use a software called winff to convert videos for your gigabeat. this is all free. enjoy
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: i need help
the OS as been delete from hdd , most of the time 'cause formatting hdd with windows
must have other Gigabeat same model fonctional , or call Toshiba and ask for repair center near you they can copy O.S. back in your Blank hdd .
Hope that help a bit
Posted on May 29, 2008
  • 175 Answers
SOURCE: Gigabeat Toshiba stalls
You r hardrive maybe faulty.
So you'll need to format it. and reload the software.
Otherwise you need to replace the hardrive.
Software here.
Posted on Oct 13, 2008
SOURCE: Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Posted on Dec 29, 2008
  • 7482 Answers
SOURCE: how do i convert mp3 music to wma.sat for my
You need a format converter to convert the mp3 to WMA. You can download a free format converter at the following website:
Good Luck, I hope this helped you Please rate me, Thanks
Posted on Dec 31, 2009
0 characters
1 Points
Is transfer from Gigabeat to iPod possible?
There are programs like sound taxi that will do it easily but they do charge for them. If all of the files are on your computer just add them to iTunes and they'll all transfer to your ipod. If not just transfer them from your Gigabeat to your computers music file. Add the file to your iTunes and then sync your ipod to your computer and all of your songs will be on your ipod. Unfortunately without paying for a transfer program you will loose all of your playlists and organization files.
Jun 01, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
I don´t have the cd of my gigabeat f20, so I can´t transfer music
HERE is a link to the software you need. Like anything you download from the net, scan it with your antivirus program before using.
Mar 21, 2009 | Toshiba Gigabeat MEG-F20S MP3 Player
Oct 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Gigabeat u202 sl, winXP sp2
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Jan 04, 2008 | Toshiba Gigabeat U202 MP3 Player
Toshiba gigabeat
gosh! where did you drop the gigabeat?? It must have been a hard fall, or in an awkward position, because I have dropped mine on cement so many times, but it has a tiny scratch on the back and nothing else.
I once had to send my gigabeat in to the company for repairs. They did a pretty good job, fixed it, and sent it back. I would recommend sending it in, because your problem seems out of your control.
Dec 25, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat windows gone
Try formatting the drive. Use either RealPlayer, Windows Media Player or Media Monkey to synchronize your music. You can drag and drop, but I dont advise that as I believe that leads to crash and format itself. DO NOT remove the USB cable while it is uploading. If you need to stop synching, you must first close the programe you're using before disconnecting.
Nov 09, 2007 | Toshiba gigabeat S MP3 Player
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEG-F20K (20 GB) MP3 Player Logo
24 people viewed this question
Top Toshiba MP3 & Digital Media Players Experts
Lawrence Oravetz
Are you a Toshiba MP3 and Digital Media Player Expert? Answer questions, earn points and help others
