Question about Canon Office Equipment & Supplies
What does system error e100 emply on canon copier ir 1210
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
Adi_Taticu
  • 71 Answers
SOURCE: i have an error in canon photocopier IR 1210 E 245
errors are not described in service manual
trying to put out the power and put it back
if not resolve, you should reset the memory
stop the copier, get out the back cover and looking for jumper JP1, him out, wait 1 min, put in place jumper, start the device. I hope to help information
JP1: jumper plug for power used by battery to back up memory (control data; user data, service
mode data).
Posted on Oct 25, 2009
  • 20 Answers
SOURCE: imageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
Posted on May 20, 2010
When to change laser unit of canon ir3300
Changing of laser is not essential...if your machine shows error E100-0001, E100-0002, E100-0003 & E110-0000 you will be must change the laser unit...
Jun 27, 2016 | Canon IR 3300 Digital Copier
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
Ir 1210 canon copier system error E-246
memory was error, you must change a DIMM or EEPROM
Apr 21, 2011 | Canon imageRUNNER 1210 Copier
IR 1210 Error cod E245
how to reset the system Err E245 in canon Ir 1210
Jul 20, 2010 | Canon imageRUNNER 1210 Copier
hi there
Jul 15, 2009 | Canon iR 2016i Black and White Copier
System Error E100
Most likely, the tab on the rear side of drum unit has broken off. Thus causing the Lazer Shutter not to open. There are 3 or 4 other possibilities other than replacing the drum unit.
Jun 02, 2009 | Canon iR 2020i Laser Printer
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
I am receiving an error of canon ir 1210- rec.
no canon ir 1210 never falt signal
Your lower cassate paper senson is open or sensor liver is broken you quary it and solve it
My cell phone is 01819879575
Mar 15, 2009 | Canon imageRUNNER 1210 Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
29 people viewed this question
old marine
old marine
