Question about Lands Phones
Panasonic modelKX-TG6071S. Dont know if our grand children hit the wrong button, when we try to make a call the message on handset is "no link to base, move closer to base try again" In-coming calls go directly to voice mail, the phone doesnt ring!
  • 1 more comment
  • barpiano Mar 12, 2009
    Prior to this, the base unit would click, when you hung up an extention phone. Don't know if this was related to current problem
  • barpiano Mar 13, 2009
    This was very helpful, I have plugged phone base back and will charge unit before trying solution! Thanks again very much!!!
    After looking thru manual, then checking our handset...to reregister handset step# 3 on page 39 say's topress the "OK" button on handset, our handset dosn't have an "OK" button???
  • 19,396 Answers
Unplug the base from power and place the handset on the base.
When you plug back the phone should reset and synch back with the handset on the base.
There is also a button to synch the handset on the base, if youpress it the handset should ring.
Posted on Mar 12, 2009
    Genius:
  • 1,268 Answers
You need to synchronize the base to sync. In doing it, please go to setting or menu of the handset and look for "sync with base" option or something like that. It will try to find the base, then you need to press the button on the base to confirm the sync process.
  • Michael Galve
    Michael Galve Mar 13, 2009
    Registering Handset
    On the handset, press Menu [0 0 1]
    On the Base Unit, press and hold LOCATOR/INTERCOM until the IN USE idicator flashes
    -After the IN USE starts flashing, the rest of the procedure must be completed within 1 minute
    On the Handset, Press OK, then wait until a beep sounds
    OFF
    Sergeant:
    Champion:
  • 435 Answers
Hi, Try resetting everything to factory settings.
You can find them in its manual.
  • 8,197 Answers
Looking at the manual you need to reregister the hand set with the base unit. Here is the manual if it will help you out.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG6071M
Good Luck and Please Rate
  • 583 Answers
Remove the battery and reinsert it to reset.
I don't remember my four digit pin
if you dont know it we dont know it try provider with a forgot password request
Sep 06, 2016 | Panasonic Kx Tpa50 Cordless Handset...
My Panasonic modelkx-tg4741will only charge on one charging stand out of four. the base will not charge. I installed new batteries in each phone
1. Check the power supply from the wall outlets being used for all phones and check the wiring connections to the phones.
2. These phones can only use Nickel metal hydride (Ni-MH) batteries. Don't use some other type of rechargeable battery such as a Ni -Cd rechargeable battery. Check that the battery installed in all the handsets is the Ni-MH type.
3. Clean the contact points on the charging stands and base unit.
4. Remove all the batteries from the handsets and clean the battery contact points.
Nov 13, 2015 | Panasonic Lands Phones
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
When i push the intercom then message button to retrieve messages it tells me invalid across the screen
while the handset is hung up (without pressing the intercom button) press the "MESSAGE" button, on the display it should show ~why~ the message light is on (cause it is possible someone tried to intercom you, then hit the wrong button) after that you can turn off your light by pressing:
1) INTERCOM
2) 700
3) *your extension #*
it is possible that the extension that turned on your message light is no longer in service, making it an invalid extension
Jan 06, 2011 | Panasonic KX-T7431 Corded Phone
I cannot use the cordless part of my panasonic KX-TC1221BXB. The following message is shown ''No link to base. Place on cradle and try again'' But even after placing back on the cradle, the same message is...
I couldn't find the exact manual for your phone but I would try to re-register the phone. Following are some instructions for similar models of your phone.
*To do this on a non-expandable cordless phone:
  • Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this fails to help: Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Mar 06, 2010 | Lands Phones
An error message is apearing on my handset,maybe a code is needed
Try this method:
Press locator button on base unit for 3 seconds. Now push flash button on handset for 3 seconds.
This MAY reregister phone to base unit. It did not work for me, more tests at http://www.panasonic.com/consumer_electronics/telephones/ts_guide1.asp
Mar 20, 2009 | Panasonic KX TG2258S Cordless Phone
Recorded messages cant be retrieved from Panasonic answering machine
You've probably done something about the problem by now but just wanted to tell you that the only items that appear on the drop-down apparently are only those the site owner has chosen to list.
I am here often and do not remember seeing nay any to add an unlisted product.
Strange thing to omit.
Aug 23, 2008 | Panasonic KX-TG1033S Cordless Phone
ModelKX-TG6051BSAYS NO LINK TO BASE MOVE CLOSER TO BASE, duh,i have it sitting on base all day,when go to make call it says no link to base.why? I did unplug roommates thought would work.But now cant even...
Your handset has somehow lost its ability to see your base. Try re-registering it to your base. To do so, at the handset push MENU 001 . Then at the base, push and hold down the INTERCOM/LOCATOR button down until the IN USE light begins flashing. Then at the handset push OK, and within a few seconds it should beep and be registered. If first not successful try again. If it still does not work, try de-registering the handset, then repeat the registration procedures I described above. Here is a link to the manual that describes these procedures, look on page 39. http://www2.panasonic.com/consumer-electronics/support/Operating-Instructions/details-KX-TG6051M
Feb 26, 2008 | Lands Phones
How do I retrieve messages left in the operator's voice mail?
If you pick up the handset and press the button it will call back whom ever left the message. (that extension you see.) If it is not the voice mail extension, it was just a request to have the receptionist call back. Doing so should clear the lamp.
Dec 13, 2007 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
62 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
