Question about Samsung Refrigerators
Samsung silver nano
My samsung silver nano 325 ltr fridge leaking water in refrigerator section.
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
kodemonkey
SOURCE: Samsung RS20CCMS side by side fridge/freezer
Just to expand on the excellent advice from woodchuckie - I had the same problem and these are the steps I took to resolve.
1) Remove the back panel. There are about 7 screws to undo.
2) The drain tube is towards the middle about 3/4 inch in diameter.
3) Remove the tube. I found a little black rubber 'flute' which I have now removed as I think this was causing some back pressure. Make sure the tube is clean and free from dusty gunk. Mine was anyway hence the removal of the flute.
4) Remove everything from the lower 2/3s of the freezer compartment. Remove the screws (some are covered by white caps) there are about six. You must remove all the screws up to the place where the top panel starts.
5) The back panel may be frozen in place. From a standing position reach down and grab the protruding plastic - pull up and out. The panel should loosen. Turn it sideways to remove it.
6) You should now see the freezer matrix and the frost free heater pipes at the bottom. If your like me you will see a block of ice at the bottom!!
7) I took a hair dryer (carfull of the water/electricity hazzard) and melted the ice (also be careful about melting the plastic of the freezer!! doh).
8) With a sponge remove the loose water.
9) The drain is in the middle and is difficult to get to.
10) I took a screw driver to the hole and jabbed at it.
11) Boil a kettle and fill the shallow tray around the drain. If your lucky the water will work through quickly and you'll hear it falling into the evaporation tray. If not then keep sponging the water out and replacing with boiling water (and have a few more jabs with a screwdriver!). Keep working it untill you have success.
12) Ensure that the interior of the freezer is dry ( I blew some air from the hair dryer through the drain and got someone on the drain at the back to confirm they could feel it coming through.
13) Replace all the plastics, back panel and screws. Put everything back in the freezer, plug it back in and set it to power freeze.
The whole thing took about 45mins - 1 hour.
Hope this helps.
Posted on May 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
woodchuck789
  • 4070 Answers
SOURCE: Magic Chef CTB1722 refrigerator leaking water from
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
  • 97 Answers
SOURCE: RS253BAWW Samsung Side fridge water leak
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Actually a pretty common concern... second time in two hours I've seen it. :D
Posted on Jul 29, 2009
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Motor constantly running stops when door of either fridge or freezer is opened but starts again when door is closed - Samsung Silver Nano
It's possible that your fridge has a fan to cool down faster your food and to prevent frost. It stops when you open the door to to avoid losing the cold.
Il you send me the exact model (for example RS7568THCSP/WS) I can add a more precise explanation.
Sep 12, 2013 | Samsung Refrigerators
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung silver nano freezer fan blades broken due to ice build up. need new blades. Please tell me where can I get Them. And how to stop it happening again.
Samsung silver nano 5yrs old - trips main electrics - 13A fuse ok but everything trips when the fridge/freezer is switched on
Aug 14, 2010 | Samsung Refrigerators
Samsung fridge is leaking water
Probably one of the plastic tubes under the refrigerator is leaking.
Apr 04, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung fridge freezer mod no SRS2028 19.3 cu, ft
the water hose runs through the bottom hinge then to the dispenser. take the kick plate off of the unit and then check for leaks. theres a coupling down there that may be yoiur problem.
Dec 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
